1978 - 1996 Big Bronco
Side-Pipes on Bronco
Old Oct 14, 2003 | 08:52 AM
drbonestou's Avatar
drbonestou
Just wanted to know what anyone thinks of side-pipes on a bronco....
If they are tucked under pretty good ..no one should (should is key word) get burnt on them...
Ok let the opinion begin
Old Oct 14, 2003 | 09:54 AM
Doorgunner808's Avatar
Doorgunner808
DO you mean like Lakewoods?? I thought of it. Mostly cuz I like to be different. But aside from that, I think they wouldnt look to bad.
DG808
Old Oct 14, 2003 | 09:59 AM
drbonestou's Avatar
drbonestou
Doorgunner...I have not looked at Lakewoods....
But I think they would look pretty good...
I would like to find a short pair...
I have the nerf bars and would like to install them between the bars and frame...
So my idea is not that far fetched?....
anyone good with photoshop??...maybe add a set to a pic..so I could get an better idea how they would look
Old Oct 14, 2003 | 10:05 AM
Doorgunner808
Yeah, thats what I thought too. Between the door sill and and the nerf bars. I'd like to see pics of that too.
DG808
Old Oct 14, 2003 | 10:14 AM
drbonestou's Avatar
drbonestou
JC-Whitney has a nice set...but I think 52in would be to long
52"L Chrome-plated Dual Side Pipes Pair 21ZX3158Y $179.99
Old Oct 14, 2003 | 10:17 AM
Doorgunner808
you could cut 'em down if needs be or just make your own??
DG808
Old Oct 14, 2003 | 10:24 AM
drbonestou's Avatar
drbonestou
I thought about making my own...then coat them with that green stuff that turns black....cant think of the name of stuff...used to paint stove pipes and stuff....
I could make them from a couple old drive shafts
Old Oct 15, 2003 | 10:10 AM
mustangman65_79's Avatar
mustangman65_79
Been, there, done that, and would do it again.
I currently have side pipes om my '89 Bronco(pics soon). The 52" would be just right. I have 50" now, and the extra 2 would work too. I got mine from Summit, but I didn't get lake pipes. I got the baffled ones with slotted cover. Simular to what u see on Semi-trucks.
At idle, they are quite, just a little rumble, but can hardly hear it. But when u open it up, man does it turn heads.
When I mounted them, I had to bend the braket straight, and drill a hole in the part where the body is wielded together, and bent down. U will see it if u get under the truck and look under the door, past the rocker panel towards the frame.
I have no smog, so I didn't worry about the cats, but u do have to hook up the O2 sensor. But Basiclly I run full lenth headers with with 2 1/2" pipe to the side pipes.
Old Oct 15, 2003 | 11:17 AM
Doorgunner808
I would love to see the pics.
DG808
Old Oct 16, 2003 | 06:06 PM
mustangman65_79
Two things need to happen before any of u get to see pics, well three,
#1, borrow a dig cam
#2 install my 33" tires
#3 clean the pipes(damn things get dirty fast)
Old Oct 17, 2003 | 03:05 PM
drbonestou's Avatar
drbonestou
WOW ..sounds just like what I wanna do...
and 52 in would be just about right size?
good deal...
I might have pics posted soon...
Old Oct 18, 2003 | 04:58 AM
mustangman65_79
Well, I now have 33" Super Swampers on a stock lift Bronco, with no rubbing at all.
So that just leaves me two things left, clean the pipes, and borrow a dig cam
bubblestumps
Jul 27, 2016 07:54 PM
rally68
Oct 25, 2015 07:05 PM
jem44357
32
Jan 31, 2012 03:15 AM
Argess
Jul 9, 2009 07:11 PM
wildsidecreations
1997 - 2003 F150
Feb 17, 2004 10:20 PM
