What fluid?
Old Mar 9, 2004 | 02:28 PM
Broncobigtire's Avatar
Broncobigtire
What fluid?
I am plaining on changing both front and rear diff lube. Wondering what brand and vis. to use? This is on a bronco. Also im going to relube the drive shaft boot thing on the rear drive shaft. Which lube for that?
Old Mar 11, 2004 | 06:06 PM
Broncobigtire
Anyone?
Old Mar 11, 2004 | 08:18 PM
BLK94F150's Avatar
BLK94F150
Probably 75w90. If it has a limited slip, you need the fiction modifier. Most Valvoline rear oil has this. Any brand should work. Make sure it's GL-5 rated.
Old Mar 11, 2004 | 08:43 PM
78fordman's Avatar
78fordman
I use 80-90 and have not had a problem. 75-90 i probably better for cooler climates.
Amish Ford
Large Truck
Aug 2, 2016 10:14 PM
Frdtrkrul
1997 - 2003 F150
Jul 13, 2015 10:24 PM
CopperBurst
Mar 21, 2015 06:25 AM
FSTBLL42
6.4L Power Stroke Diesel
Feb 27, 2011 08:43 AM
slothshady
Oct 26, 2004 01:45 PM
