Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Rear End Lube
Old Jul 31, 2016 | 04:44 PM
Amish Ford's Avatar
Amish Ford
Rear End Lube
What do I use for Rear End Gear Lube in my 1974 F700? How much?
Old Jul 31, 2016 | 07:22 PM
85e150's Avatar
85e150
Page 3 if it comes up:
http://www.eaton.com/ecm/groups/publ.../ct_070589.pdf
Short answer: 75W-90 of any stripe or 80W-140. That info specs synthetic, so on an older truck you might want to stick with dino oil in similar weights.
Any gear oil for hypoid gears will work, you don't need anything fancy.
How much? Not sure on the quantity, but it should run out the fill hole. 2 to 4 gallons is a wag.
Old Aug 2, 2016 | 10:14 PM
awhtx's Avatar
awhtx
75w90 and 80w140 are both synthetics. 80w90 is conventional oil.
pburress
Feb 25, 2012 09:57 PM
scatgo
Sep 6, 2010 10:50 AM
jimwilsonmasonry
May 13, 2008 08:32 PM
JBD94F250
Jul 7, 2004 05:53 PM
PigFarmer
Oil & Lubrication
Nov 2, 2002 12:11 PM
