Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Impact wrench question
Old Mar 8, 2004 | 08:57 AM
maa139's Avatar
maa139
What determines the torque that an impact wrench has? They basically all look the same so there has to be somethig internal in the design that determines torque. The reason that I'm asking is I just got a Chicago Pneumatic that is rated at 360 ft-lbs max torque. When I use it, it doesn't seem to be much different from the 250 ft-lb campbell hasufeld wrench that I have. I'm assuming that the higher rated wrench should spin off lug nuts faster?? Is that correct?
Thanks.
Old Mar 8, 2004 | 09:06 AM
Torque1st's Avatar
Torque1st
Posting Legend
Spin rpm can vary and does not have anything to do with the torque a tool develops. The internal design dictates torque. Ratings can "vary" from one manufacturer to another, -if you know what I mean...
Old Mar 8, 2004 | 09:32 AM
beartracks's Avatar
beartracks
The air pressure you use has the most direct effect on torque. Some guns are just made better/more efficient internally.
Old Mar 8, 2004 | 09:50 AM
maa139's Avatar
maa139
Yep, I hear you. I just thought it funny that the 'cheap' brand seemed to break the lug nuts lose just as quickly as the 'good' brand...
Old Mar 8, 2004 | 12:07 PM
Sberry27's Avatar
Sberry27
Where it doesnt need its max power this may be true,,, but that cheapie wont last like the CP though. I train my men to oil the bolts first and remove/install these nuts slowly too,, speed kills and makes for heat, tends to sieze the nuts.
Old Mar 12, 2004 | 02:00 AM
mark a.'s Avatar
mark a.
Switch to the big chucks you'll see a big difference.
One Sock
Garage & Workshop
29
Apr 24, 2014 02:24 PM
dchamberlain
General Automotive Discussion
Aug 19, 2010 04:42 PM
88grandmarquis
Garage & Workshop
Sep 26, 2005 01:30 AM
04SilverSCFX4
Garage & Workshop
25
Aug 9, 2004 08:28 PM
WoodN1_76
Garage & Workshop
24
Sep 25, 2003 04:22 AM
