Y-block transmision
Old Mar 7, 2004 | 07:32 PM
Fordication's Avatar
Fordication
Y-block transmision
Is there any way to attach a c-4 or c-6 or any other auto transmission to a y-block without paying 500+ for an adapter? Ed
Old Mar 7, 2004 | 08:28 PM
pcmenten's Avatar
pcmenten
The FMX transmission will bolt to a stock truck automatic bellhousing with some work. It's been documented and is described on other y-block web forums.
Some people will deprecate the FMX but it lives behind many high torque engines like 390's and 351C/4V. If I am recalling correctly, it has the advantage of being able to be push started if your battery goes dead. Most other automatic transmissions won't do that.
Old Mar 7, 2004 | 10:19 PM
Fordication
I have not heard a great deal of good about the FMX. Does it have 3 gears and can you start the truck off from first. Ed
Old Mar 8, 2004 | 05:32 PM
286merc's Avatar
286merc
The FMX conversion uses some CruiseO Matic parts.
Nothing wrong with the FMX except weight, Summit even carries a performance kit for it.
I ran one for years behind a honkin' 390 and never a problem, even towing a loaded car trailer.
Old Mar 8, 2004 | 06:48 PM
darkman's Avatar
darkman
FMX is a heavy dependable transmission that will handle severe abuse in a drag car. Only drawback is weight. I will be using it in my 57 F100. You can use factory mounts, shifters, linkages, driveshaft, speedometer cable, etc................
Old Mar 8, 2004 | 09:09 PM
286merc's Avatar
286merc
And yes, the FMX is a true 3spd selectable tranny; it is the forerunner of the C6.
jaye
Sep 27, 2008 07:57 PM
gritsngumbo
Jul 31, 2008 05:21 AM
jamesey138
Mar 2, 2005 09:01 AM
Fordication
Jul 29, 2004 08:55 PM
KJB
Oct 24, 2001 05:01 PM
