Automatic for Y-Block?
Old Jul 30, 2008 | 03:02 PM
gritsngumbo's Avatar
gritsngumbo
Are there any automatic tranny's which are a direct bolt up to the Y-block engines? Or which use an easy to find bell housing or adapter?
Old Jul 30, 2008 | 03:42 PM
85e150's Avatar
85e150
Ford-o-matics were the only direct bolt up, you can still get rebuild kits for them. These became the Cruise-o-matic, then morphed in the FMX later, but all the bell patterns are different. One of the joys of being a Ford man...
Adaptors exist to adapt the AOD but it's $850 for the adaptor including the starter. Scroll down just over half way here:
AOD Transmission from PATC, AOD Transmissions
Someone here has an E4OD on a Y, not sure how he did it.
You may also want to contact:
Advance Adapters.Com Engine & Transmission Conversion Adapters
I think they are the source of the trans center adaptor anyway, and they may have others.
Old Jul 30, 2008 | 05:37 PM
kooper909's Avatar
kooper909
I have a Ford-O-Matic out of a '56 Ford car if you are interested. I would sell it complete with bellhousing, flexplate, torque converter, kickdown linkage, etc.
Old Jul 30, 2008 | 05:41 PM
gritsngumbo
Thanks for the offer. At this point I'm exploring my options on which way to go.
Old Jul 30, 2008 | 06:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I just answered this question a few minutes ago for another member.
1961/64 F100/350's with 292's used the 3 speed FX Cruise-O-Matic, not a Ford-O-Matic.
The FX C-O-M is the little brother to the MX C-O-M used in 1958/67 FE cars (exc 428's), 1965/67 F100/350's with the 352.
Find one a those 1961/64's with a C-O-M, swap everything over.
The crossmember that's riveted to the frame where the tranny mounts fit is the same for a M/T or an A/T, so everything is a bolt on operation.
Old Jul 30, 2008 | 07:52 PM
85e150's Avatar
85e150
Hhhmm, I'll have to find that other post where I gave the guy bad info regarding F-O-M and have him look here. Thanks again for correct info.
Old Jul 30, 2008 | 11:57 PM
JimKoz's Avatar
JimKoz
The September 1999 issue of Street Rodder Magazine had a story devoted to using the FMX behind a y-block. It was part #7 of a series of articles that year titled "Y-Notta Y-Block".
Flat-O Products sells adapters to mount a C4 behind the y-block too.
The Y-Block
Old Jul 31, 2008 | 05:21 AM
NumberDummy
Just to clarify: The FMX is not a FX C-O-M.
The FX (small C-O-M) and MX (big C-O-M) were introduced in 1958.
The FMX was introduced in 1969.
Fordication
48
Dec 9, 2013 12:05 AM
leadmic
Car/truck Buying Advice
Feb 25, 2002 06:33 PM
KJB
Oct 24, 2001 05:01 PM
Kenny
Aug 8, 2001 06:03 PM
copeina
Mar 29, 2001 09:47 AM
