1978 - 1996 Big Bronco
Which headers
Old Mar 7, 2004 | 10:21 PM
WhëëlMå1's Avatar
WhëëlMå1
Yes, I believe they bolt up to the stock Y.
Old Mar 8, 2004 | 02:02 PM
NJbronco138's Avatar
NJbronco138
well PP gave me like 60 bucks off bassani's and about the same off of JBA's and I didn't have to fight with him I just explained what I would like to happen to get this out of the way. I went with the Bassani's just so the brands would be the same and hopefully make it easier for the shop put them together, plus even with the price break JBA's are super expensive. I hope once i get them. I can have these problems solved.
Old Mar 8, 2004 | 02:27 PM
WhëëlMå1's Avatar
WhëëlMå1
For the sake of youre sanity, I hope this does solve youre problem.
Rich
Old Mar 8, 2004 | 03:52 PM
NJbronco138
yeah me too. I am tempted to try to install the headers myself and see if they will fit with the y pipe, so i won't have to pay a shop. But my luck they won't fit their y pipe or the stock one and i will have to put the manifolds back on, but I can't because they cracked in half. Well, atlest the y pipe bolts came off without problems and thats half the batle from what i have read. so maybe it won't be to bad to try to install the headers myself.
Old Mar 8, 2004 | 05:13 PM
94F150-408's Avatar
94F150-408
Good Luck, NJ, I hope your project goes well now. Maybe having a shop do it would save alot of frustration?? Either way I hope it runs great!!
Old Mar 8, 2004 | 05:31 PM
NJbronco138
yeah, thats what I'm thinking too. I need to ask the shop how much it will cost for the work. If its a lot I might need to take a shot at it
Old Mar 8, 2004 | 09:58 PM
Wakeboarder141's Avatar
Wakeboarder141
How difficult is it to install the Y pipe? I was debating buying just headers now or doing headers and Y pipe at once. Do you need to be able to weld to do the Y pipe? Thanks.
Old Mar 8, 2004 | 10:04 PM
94F150-408's Avatar
94F150-408
The Y pipe goes where the existing factory Y is...between the exhaust manifold exit (or Header collector flange) and the front of the catalytic converter, so if your pipe is welded to your converter now, you would have to cut that and use a u bolt, that is if you dident want to go to the muffler shop and have them weld it back on. I personally prefer welded exhaust. I'm off rod alot and pretty rough on it. I dont want anything coming off!
GT4point6
Modular V10 (6.8l)
Sep 8, 2007 10:27 AM
02q45
Modular V10 (6.8l)
Jan 31, 2007 01:57 PM
valdezvip
Exhaust Systems
Mar 24, 2005 04:30 PM
sdrowand
Feb 11, 2004 04:18 PM
none
Dec 8, 1999 06:54 PM
