1978 - 1996 Big Bronco
Fuel filter (s)??
Old Mar 8, 2004 | 06:13 PM
Broncobirdy's Avatar
Broncobirdy
Fuel filter (s)??
Are there more than the main one that is bolted on the inside frame on the drivers side? Mine is a 93 5.0L
Old Mar 8, 2004 | 08:13 PM
Roger Carter's Avatar
Roger Carter
I cannot speak to a 93 rig but I do know that on an late 86 full size, 5.0L with EFI, there are two fuel filters. The "second" filter is in the "usual" spot, under the driver's floor, attached to the inside of the frame rair. The "first" filter is tucked above the transfer case crossmember, attached to the driver's side frame rail. This one is hard to see and harder to replace.
Roger Carter
Old Mar 8, 2004 | 11:53 PM
bigric's Avatar
bigric
'93 only has the one filter along the frame rail. Earlier models had two.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
