Sponsored by: Auxito
steering stabilizer mod?
Old May 3, 2012 | 06:05 AM
kbsupercrew's Avatar
kbsupercrew
2000 f150 4x4, stock height, running 285s, I have heard good things about steering stabilizers being added to improve handling. Has anyone done this mod to their stock height 1997-2003?
If so, how was the result? what brand did you use? worth it? TIA
Old May 3, 2012 | 07:01 AM
00GT's Avatar
00GT
I used a Fabtech steering stabilizer on my 98 I had but I was running 35's i was getting a front end shake. Added the stabilizer it was smooth again.
Old May 3, 2012 | 05:06 PM
kbsupercrew
Nice, but I read the fabtech with only work with their lift kit, I'm trying to search for pics of different stabilizers and how they are mounted, they seem to each have their own mounting position on these trucks.
The search continues
Old May 3, 2012 | 07:45 PM
04mudslinger's Avatar
04mudslinger
I used a pro comp one. Night and day difference to improve handling after installing torsion keys to lift the front 2". I didn't totally mount it as instructed. Instead of replacing the lower A arm bolt with the supplied longer one, I used a short bolt and mounted it to the crossmember to the left of said bolt on passenger side (looking forward from rear).
Old May 3, 2012 | 08:09 PM
00GT's Avatar
00GT
Really? That's weird....I remember mine mounted in such a way that it didn't matter if it was lifted or not. Maybe they have changed. I guess I should have taken pictures.
Old May 4, 2012 | 06:43 AM
kbsupercrew
4wheelonline.com/images/fabtech/.../Fabtech-install_FT8003i.pdf
says it wont work with out their system in first paragragh
Old May 4, 2012 | 06:57 AM
kbsupercrew
Mudslinger was your pro comp really close to the 4wd vacuum housing? any issues with that ?
Old May 4, 2012 | 10:09 PM
04mudslinger
No issues with it, but it is close. No rubbing. Mine looks exactly like the one pictured in the second post here: http://www.f150online.com/forums/sus...tabilizer.html
Old May 6, 2012 | 08:42 PM
liftnw8z's Avatar
liftnw8z
I have all the makings of putting a Rancho stabilizer on my truck, but I've got cooler lines in the way. One end mounts to where the idler arm goes, and the other to the drag link. I just have to figure out how to move the cooler lines safely to not get interference, or destroy the lines.
Old May 6, 2012 | 09:07 PM
kbsupercrew
Steering stabilizer - Ford Expedition Forum
I saw the rancho and the moog here mounted
I might go with the moog
I wonder whats the diff between the moog and the rancho except price
Old May 7, 2012 | 09:10 PM
kbsupercrew
Well I ordered the moog ssd122, will post pics and maybe a video!
Old May 13, 2012 | 10:00 AM
kbsupercrew
Well an update, I had to return the mood kit due to missing brackets. I was wondering if moog doesnt make shocks, what brand are they using in their kits?
Does anyone have the shock number for the pro comp stamped at the base of it?
The moog I recieved had 81288-0rp
MILAGRO33
Mar 27, 2019 04:59 PM
ZestyCj7
May 26, 2007 08:08 AM
95bogginbronco
Offroad & 4x4
Jul 20, 2005 03:56 PM
paramedic624
Aug 23, 2004 12:36 PM
paul 03
Aug 3, 2004 04:04 PM
