Modular V10 (6.8l)
used v10?
Old Mar 5, 2004 | 09:13 PM
JustMyLuck's Avatar
JustMyLuck
used v10?
I just purchased a used 2000 Excursion with a V10 & 4.30 ls rear end. It has 72000 miles and I have no maintenance records. What should my first priorities be as far as getting things checked out. This is the first used vehicle that I have purchased and I am not mechanically inclined. I bought the vehicle pretty cheap and am not apposed to investing some money into it but not sure where to start? The oil was changed with 10w30 a week ago. Thanks for any hep.
Old Mar 5, 2004 | 09:26 PM
JustMyLuck's Avatar
JustMyLuck
I dont know what is worse....my typing or spelling?
Old Mar 6, 2004 | 05:13 AM
HeavyAssault's Avatar
HeavyAssault
Just drive it. Put about 5k more miles on the clock. If anything develops, fix that problem first.
Besides after 5k you will be very happy or an unhappy camper.
You could have all fluids changed; front diff, tranny & filter, transfer case, rear diff and the anti-freeze.
Old Mar 6, 2004 | 08:50 PM
V10man's Avatar
V10man
Well, start by using the correct oil. 5W30. A tranny flush wouldn't hurt either.
Old Mar 6, 2004 | 08:59 PM
JustMyLuck's Avatar
JustMyLuck
The oil was changed before I bought it, should I drain it and replace it or wait for 3000 miles?
Old Mar 8, 2004 | 12:36 PM
jasontrucks76's Avatar
jasontrucks76
I just bought a 2002 f-250 v-10 with 67000 and I made it part of the deal but I had the Ford dealer flush the Tranny, change the plugs, front and rear dif. and do an over all check. I am friends with a Ford mec. and he said the 100,000 mile plug thing is not advised by him he would recomend 60 to 70k change and from now on I would run 5-20 motorcraft
Congrats on the new truck
take care
Jasontrucks
Old Mar 8, 2004 | 04:57 PM
JustMyLuck's Avatar
JustMyLuck
I had a transmission shop look at it and do a diagnostic test. They said everything was fine and they did a flush job. I asked if they thought they should drop the pan, which was more money, and they did not reccomend it at that mileage. I think I have a small exhaust leak, it sounds like it anyway. I am getting the brakes checked and two new Steeltex A/T for the rear, so I will have that shop check for the exhaust leak. I guess this is all I will do for now and see how she does towing the Sea Ray this summer. If I need new brake pads, any suggestions. Almost all miles will be towing 10,000lbs.
Old Mar 9, 2004 | 07:35 AM
jasontrucks76
I like the ceramic pads the do not get as hot and seem to last twice as long!
JT
Old Mar 14, 2004 | 05:13 PM
Knight Prowler's Avatar
Knight Prowler
I have 4 of those Steeltex 265/75/r16 with only 2000 miles on them if you are interested. I can send pics if you are interested.
Ron
jaymers
Sep 13, 2010 09:42 AM
JohnnyTwoToes
Jul 4, 2010 12:04 PM
Paul T
Dec 31, 2008 11:35 AM
cajundaddy2
Modular V10 (6.8l)
40
Mar 3, 2006 03:03 PM
Agronomist
Nov 11, 2005 07:29 AM
