Modular V10 (6.8l)
5W30 in a V10
Old Feb 9, 2006 | 06:23 PM
cajundaddy2's Avatar
cajundaddy2
5W30 in a V10
I have just purchased a 2005 motorhome on a Ford V10 cutaway van chassis. The van's owners manual calls for 5W20 oil but since I live in Southeast Louisiana where summers are quite warm I was wondering if I could use 5W30 instead. I have always used full synthetic 5W30 in all of my vehicles and would like to do the same with this one. Thank you for any advice that you have to offer.
Cajundaddy
Old Feb 9, 2006 | 06:25 PM
ford390gashog's Avatar
ford390gashog
i would not. i would run the spec'd 5w20 with the Fl820s filter.
Old Feb 9, 2006 | 06:54 PM
DJR 17's Avatar
DJR 17
I've run Mobil 1 5w30 for 4 years now, the only issue I have is it uses up to 3 quarts between 5000 mile oil changes.
Old Feb 9, 2006 | 07:35 PM
ford390gashog
thats a lot of oil being used. most people report zero oil loss.
Old Feb 9, 2006 | 07:57 PM
Wrenchtraveller's Avatar
Wrenchtraveller
Lot's of posts on this. 5-20 works well in warm climates too. Your engine is running a lot warmer than the temperature outside and these engines were designed for the 5-20.
I work mine hard towing and my V10 does not use any oil between changes with Motorcraft 5-20. The guys using full synthetics report oil useage and we have guys with high mileage V10s that have always used MC 5-20. It is cheap priced when you buy it at Wallmart, so I am going to use it in my V10, why spend more?
If you really want to run 5-30 , I am sure it will be fine.
Old Feb 10, 2006 | 06:03 AM
KRB's Avatar
KRB
Must read article on oil !!!!
Go to www.lincolnsonline.com/article105.html and take the time to read. I even printed out a copy for reference. There is important information here about synthetics too. This is a must read for everyone! Especially if you experience what you think is oil usage on a good running engine.
Old Feb 10, 2006 | 07:54 AM
DJR 17's Avatar
DJR 17
KRB, the link doesn't work.
Old Feb 10, 2006 | 08:11 AM
KRB's Avatar
KRB
Sorry about the link
Try this one www.lincolnsonline.com/tech/00105.hmtl . It worked just now.
Old Feb 10, 2006 | 08:23 AM
DJR 17's Avatar
DJR 17
I think this might be the link: http://www.lincolnsonline.com/tech/00105.html
DJR 17's Avatar
DJR 17
yep, sorry I didn't refresh before I posted the link..
Old Feb 10, 2006 | 08:27 AM
DJR 17's Avatar
DJR 17
Pretty good stuff, but he didn't get into why you shouldn't add or top off your oil, other than it might be getting gas contamination. I drive a lot of city and hwy miles, I haven't noticed any gas in my oil. 163000 miles and all of it on Mobil 1 5w30.
Old Feb 10, 2006 | 01:24 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
To be truthful, these engines were designed for 5w30. Whether or not Ford made any changes to the bearing clearances or oil pump after the change to 5w20, who knows? I doubt it though.
I ran 5w30 in my 4.6L's for 7 years before I got the V10 and the previous year's V10 called for 5w30 with no apparent changes in part #'s or anything else.
So, I run Castrol dino GTX 5w30. I put in Castrol Syntec 5w30 recently, gotta change it soon. I'll probably go back to dino.
Old Feb 10, 2006 | 06:08 PM
RBC-01's Avatar
RBC-01
The new engines have tight tolerences but the thin oils are used for EPA milage and saving emmission componets that the manufacture is on the hook for long after your engine warranty has expired.
Watch Toyota for 2007, factory fill's and recommendation are going to be 0w-20 in everything they build.
Old Feb 11, 2006 | 02:35 AM
ford390gashog
well i will bet money they won't. toyota has already tried with some bad results. they may have made the 5.7 able to run it , but the 2.4 , i force v-8 and the v-6 used in the tacoma did not do to well.
Old Feb 11, 2006 | 07:43 AM
bterry's Avatar
bterry
KRB (and DJR 17), thanks for posting the article. It was kinda long, but well worth the time to read it. I usually put 1 qt of full synthetic in with each (dyno) oil change. Heard it was a good idea once, but never got much confirmation on it. The article didn't convince me that it was a bad idea, only reinforced it was probably better than not. At least that's what I read into on the subject. I'm going to change my oil today - 10w30 with one qt of synthetic added.
