Inline 6cyl. HELP!!!
Old Mar 4, 2004 | 06:45 PM
topnotch50's Avatar
topnotch50
Exclamation Inline 6cyl. HELP!!!
I have a 1981 F100 Custom and was recently experiencing a sputtering troblem at acceleration.I replaced the Carb.,fuel filter,fuel pump,starter,starter relay,voltage regulator,all gaskets,and today a new performance coil.I have gotten it to start but it will not stay idle.I thought maybe "timing" and set it to spec via. Chilton by rotating the crank to 6 deg. BTDC and aligned rotor with the distributor.Now,as I turn the egine over it will not start and is blowing fuel form the top of the carb like it is burping it out.That's the easiest way for me to explain it.I'm lost and don't know what to do next.Can anyone please help me?
Old Mar 4, 2004 | 09:12 PM
cdherman's Avatar
cdherman
First off -- try this. The float or needle may be stuck one the rebuilt carb. This will cause vastly too much gas, that then bubbles out the float bowel vent tube. Take a piece of wood, like a hammer handle, and thump on the area of the carb over the float bowel. I assume you have a Carter YFA, based on the year. You need to jiggle the needle loose -- they get stuck after a while.
Rebuilt carbs are NOTORIOUS for being junk. Hope you bought from a reputable place. If that doesn't help, I'd start by getting a different one. Many folks will suggest that you throw in the towel and buy a rebuild kit and rebuild it yourself -- not really that hard, as I understand it. But I havn't personally done that either, so caveat emptor.
Old Mar 5, 2004 | 08:02 AM
topnotch50's Avatar
topnotch50
The carb I bought the first time did the same thing so I thought I just got a bad rebuilt carb.I took it back and returned it for another and it is still doing the same thing.Another question though,to get the #1 cyl. TDC I took out the #1 plug,inserted a screw driver and manually turned the crank until the cylinder was all the way up,right before it going back down I stopped and set the distributor, I also tried it by Chiltons by turning the crank until the timing mark lined up 6deg. BTDC and set the distributor and I get the same results either way.
Old Mar 5, 2004 | 08:08 AM
cdherman's Avatar
cdherman
Those methods are good for getting basic timing and verifying that the timing mark is not off completely. But I think you should get a timing light for the fine work.
I don't see how timing is going to shoot gas out of your carb though,
Old Mar 5, 2004 | 06:07 PM
300inline6's Avatar
300inline6
I had a simular problem with mine after I added my new cam. I found that the rocker nuts had backed off and some of my valves weren't opening causing it to blow back through the intake. I replaced them and tightened them back down and all was good.
Old Mar 6, 2004 | 02:59 AM
NM5K's Avatar
NM5K
I wonder about this for one thing... Normally, you set the crank to TDC "#1 piston up" and then set the rotor position. Not at 6 deg BTDC. You should set the base timing to 6 deg once running with a light. Remember to unhook the vacuum advance when you set timing. It's possible for a carb to mimick this type of problem, but to me, it sounds timing related. Make sure the gear pin is not sheared on the base of the distributor, things like that...Make sure the little wires in the distributor are not frayed, etc...Timing problems can make a carb spit, and also backfire. If the valves were too loose, you would have noticed an awful clacking before this happened. Pretty unlikely...MK
Old Mar 6, 2004 | 06:22 AM
Ford_Six's Avatar
Ford_Six
Run a temporary ground from the distributor to the battery negative terminal. I had similar symptoms a while back, and it turned out to be a bad gound.
Old Mar 6, 2004 | 12:29 PM
5_labsownus's Avatar
5_labsownus
Do a compression check on all Cyl's. By the way I took 4 remand carbs to make me replace it carter with a 4bbl and intake!
Old Mar 6, 2004 | 01:32 PM
MontanaFord's Avatar
MontanaFord
When I replaced my valve cover gasket, I found that I could move a few of my rockers...I didn't tighten anything, but every now and again, I hear something that sounds like metal slapping metal...Is this caused by the loose rockers? How tight do I tighten the nuts down on the rocker studs?
MontanaFord
Old Mar 6, 2004 | 10:27 PM
300inline6's Avatar
300inline6
MontanaFord
If your rocker's are like my '79 300 6 and aren't the adjustable kind you just tighten them down and torque them to 17 to 23 ft-lbs.
Old Mar 9, 2004 | 01:56 PM
topnotch50's Avatar
topnotch50
Well,I sent her to the shop today.I tried everything I could and got nothing.I can't wait to here what the Mech tells me.Thanks to everyone who replied!I will keep you posted on the outcome.
Chwbauka
Dec 5, 2009 02:48 PM
Duksrule
Jul 1, 2009 10:03 AM
48' fordster
Flathead V8 & Flathead 6
Nov 9, 2007 08:09 PM
slyde
Dec 18, 2005 10:09 PM
6772crewcabs
Jan 19, 2002 08:31 PM
