Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
dash light
Old Mar 4, 2004 | 07:35 AM
kws27's Avatar
kws27
dash light
anybodys dash light were you see you P,R,N,D icons ever go out
My light right there went out how hard is it to replace.
Old Oct 11, 2004 | 05:46 PM
4250's Avatar
4250
I have the same problem The bulb burnt out twice but I am not under warranty any more. let me know if you find out how to change it
Old Dec 2, 2004 | 12:24 AM
EFF250's Avatar
EFF250
Mine is out too!!!!!
Old Dec 2, 2004 | 04:00 PM
ove1's Avatar
ove1
To replace the backlight for the odometer display, just disconnect the battery and remove two screws from the instrument cluster bezel. Position the shift lever and steering wheel tilt so that you can pull it off. That will expose 4 additional screws that hold in the instrument cluster. Remove those and pull the cluster out far enough to disconnect 3 connectors on back. Once you have the cluster out, the bulb behind the odometer display will twist out. The bulb is available at most auto parts stores.
beckman
25
Sep 7, 2018 10:58 AM
cefloyd
Jul 12, 2012 10:50 PM
Winberry Farms
Apr 22, 2008 03:55 PM
Munch
Jul 4, 2006 05:26 PM
WXboy
1983 - 2012 Ranger & B-Series
Dec 28, 2002 09:06 PM
