1971 ford truck dash lights
Im going through the same problem. Ive been told that the whole light/headlight switch needs to be replaced. I also didnt realize that these trucks could dim their dash lights by turning the **** counter clockwise or vise versa..but sadly..this did not fix anything. So a new switch it is.
D3ZZ-11654-A (replaced C5DZ-11654-A; C5TZ-11654-A, B & C) .. Headlamp Switch Kit (Motorcraft SW-1245).
Original 1965/72 F100/350 switch marked: C5TB-11652-A or D2TB-11652-AA.
Applications: 1965/72 F100/350 / 1966/76 Bronco // 1965 Mustang from 8/17/64 to 11/16/64 / 1966 Mustang / 1970/72 Maverick/Comet / 1971/72 Mustang.
Yes, rheostat is what I needed to call it, but in technical terms it's a variable resistor. The bakeolite material from back in the day was very time sensitive and cracks with age. Then you include any carbon arcing from using it, the conductivity goes away and the dash lights fail to come on.
My '69 F100 is in dire need of a new headlight switch. I always have to "giggle" the **** to find the one spot that makes the dash lights work. I've had the truck 23 yrs.....I'll get around to it someday LOL!!
dash light bulb
I don't have dash lights.
Is the dash light bulb(s) accessible from under the dash or does one have to get to it by taking the whole panel off?
Figured I'd try to check this first (well, actually, changing all the fuses was first) and I'll try the other suggestion of checking that switch too. Other than that, I'm assuming the bulb might be burnt out.
Yet now seeing this thread, and having had issues with a wiper motor I replaced lately, I see the same issue being found - old wiring lol.
I will change switch when I change my rusty cab one of these days ( my 71 350 cab has a switch lol)
Found you can rewire these trucks one wire at a time. I'm opting for new wiring harness complete when I do my swap. Cheap option too!
Good thread, got me thinking again lol
on
There's a 'secret' to removing the switch. When you need to remove the **** from the switch housing, depress the little spring-loaded button that's on top of the switch housing. It's inside, you'll have to reach up under the dash to find it.
Otherwise, it's SOP; disconnect the battery, loosen the bezel, disconnect the connector etc.
Last time I had to change out the light switch, it came with a bracket that wasn't mounted to the switch housing. I glued the bracket in place with some JB Weld.
Thipdar great tip on the JB Weld for that bracket. It is definitely a great trick and just used the same on mine. Otherwise you need 4 hands and a set of mirrors I swear! Especially on mine as the AC unit goes under the column and has a vent right under that switch. A MAJOR PITA even with that bracket attached for mine!
