Sponsored by: Real Truck
Dash Light Replacement
Old Apr 22, 2008 | 12:42 PM
Winberry Farms's Avatar
Winberry Farms
I have a light out in my dash beside my tach. I was wondring if any of you had changed dash lights before? Its it a bitch or is it easy?
Thanks
Old Apr 22, 2008 | 02:42 PM
ReAX's Avatar
ReAX
I had my cluster out for another reason, and while I was there I replaced a couple of bulbs. It's easy once you have the cluster out, it's just 1/4 turn sockets. They are rubbery and deep in the plastic, but a pair of needle nose pliers makes short work of it.
To get the cluster out, (99-07) you have to pull the radio, put the trans in first gear, tilt the wheel down, pull the dash bezel loose, disconnect the accessories and head light switch. Once you have that big bezel out of the way the cluster is held in with 4-8 bolts, the transmission indicator unclips from the bottom and there are a couple of harnesses in the back of it. It's been a while, but it is pretty self explanatory once you get in her.
Old Apr 22, 2008 | 03:06 PM
Winberry Farms
I see they made the really convient to get to...what were they thinking?...
Old Apr 22, 2008 | 03:55 PM
ReAX's Avatar
ReAX
Other than the huge bezel, it's a typical cluster arrangement.
Skyler Hewitt
Dec 14, 2015 09:59 PM
akpolaris
May 27, 2014 04:44 PM
T_199
Apr 25, 2014 05:04 AM
rpenterics
Feb 17, 2014 08:27 AM
