engine shutdown
Old Mar 1, 2004 | 06:38 PM
mandyoh's Avatar
mandyoh
engine shutdown
I am hoping someone can help with this....the engine in my 94 deisel will shut down and then restart...there is no warning and I lose no radio or lights.....i call it a hic-up.......
thanking you in advance for your help
Old Mar 1, 2004 | 09:29 PM
ltfox's Avatar
ltfox
Need to know what kind of truck ya got. Is it the turbo, non-turbo or powerstroke ford diesel? Ford used all of them in 94. If its the powerstroke i'd bet you have a bad cam sensor.
Old Mar 1, 2004 | 09:31 PM
75diesel's Avatar
75diesel
check for a loose connection at your fuel shut-off solenoid on the injector pump, or possibly corrosion.. it should be the connector at the middle, driver's side on your injection pump, if not use a test light at this connection and move your wiring harness around with the key on to see if the wiring is at fault. Also it could be the ignition switch at the lower end of the steering column..But start with the pump and let us know what you find..
Old Mar 1, 2004 | 09:50 PM
ltfox's Avatar
ltfox
Sorry off the topic but I got a ? for 75diesel. What is the nv4500 5 speed tranny. What is it out of. I've never heard of it?
Old Mar 1, 2004 | 09:57 PM
75diesel's Avatar
75diesel
the nv 4500 is the same trans used in chevy and dodge 3/4-1 tons, the dodge diesel has a bigger input shaft though. Approx 27% od. mine is the 95 chevy version with the best parts of all the years chevy used them, I worked at a GM dealer to pay for my toys, what can I say?
Old Mar 1, 2004 | 09:58 PM
75diesel's Avatar
75diesel
sorry, New Venture 4500
Old Mar 2, 2004 | 06:39 PM
mandyoh's Avatar
mandyoh
Thank you for the help with the engine problem....my truck is 1994 Ford turbo....direct injection...if that helps any....thanks again for any answers you might have
Old Mar 2, 2004 | 06:45 PM
trackspeeder's Avatar
trackspeeder
Most likely its the cam sensor.
Old Mar 2, 2004 | 06:48 PM
mandyoh's Avatar
mandyoh
Thank you itfox and trackspeeder...i will dig out my manual and see where the cam sensor is.......
Old Mar 2, 2004 | 07:27 PM
ltfox's Avatar
ltfox
If you go to the 94-97 powertroke forum you'll find someone to tell you all about it.
XionTheBrony
33
Feb 28, 2013 10:59 AM
flipklos
Dec 14, 2007 02:18 PM
stiffysteele
Mar 22, 2004 07:37 AM
lr
May 27, 2002 08:17 AM
mtraum
Oct 26, 2001 03:30 PM
