Subwoofer!!
Old Feb 28, 2004 | 09:44 PM
JerNla's Avatar
JerNla
Lightbulb Subwoofer!!
I have a 2000 wiht the MACH and a subwoofer. Does anybody know how to take the cove off. Any hepl would be greatly welcomed!!
Old Feb 29, 2004 | 02:40 AM
tmajikman's Avatar
tmajikman
Don't try to take the cover off. I found out the hard way. Cost on the cover is $85.00. Take the whole side off and save yourself some money.
Old Feb 29, 2004 | 08:02 AM
JerNla's Avatar
JerNla
Thanks for the info prolly saved me 85.00. But one question how do you go about taking off the side??
Old Feb 29, 2004 | 02:13 PM
tmajikman's Avatar
tmajikman
the side is held together with plastic insert that pop in and out. You can use a screw driver to get them stared. Pull the piece that covers the rear carpet first to make it easier. You should not have to totally remove the side cover to get the subwoofer out. Let me know if you have any other questions.
Old Feb 29, 2004 | 03:36 PM
96explorereddieb's Avatar
96explorereddieb
Removal and Installation
Here's how you should remove it: From the shop manual:
1. Remove luggage compartment cover (45440) from retainer, if equipped.
2. Remove front door scuff plate (13208).
3. Remove liftgate scuff plate.
4. Remove front safety belt anchor bracket (612K54).
5. Remove rear seat belt anchor from B-pillar.
6. Remove side window latch.
7. Remove quarter trim panel (31012) attaching screws and pushpins. Remove body side trim panel.
For installation, follow removal procedures in reverse order. Make sure quarter trim panel is installed correctly over the door weatherstrip. Tighten front seat belt attachment-to-floor and rear seat belt anchor-to-B-pillar bolts to 30-40 N-m (22-30 lb-ft).
The subwoofer is in plain sight if you do everything correctly. Good luck!
1999XLT
Garage & Workshop
28
Jan 15, 2010 08:04 AM
Mike W
21
May 20, 2004 12:43 PM
ctfordguy
2004 - 2008 F150
Apr 21, 2004 09:04 AM
Cool1996
Oct 28, 2003 05:11 PM
scottincincinnati
19
Jan 24, 2003 05:05 PM
