Craftsman Bolt-Out Tool
What type of bolt out tool are you referring to? There are many kinds.
More details on this please...
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
And i think 1999XLT found out it did
Wiz
[link:www.clubfte.com/users/thewiz427/index.html|"Wiz's Place"]
I have seen those screw extractors on TV and they look like they would work great. I have used left handed drill bits for years to back out screws and bolts, the only bad thing about them is they tend to "drill" too much. Those screw extractors may have that covered :-)
>guys have descriptions and part numbers?
Now if someone would make a tool to fix screw-up's. I would buy one. Yesiree, make that two.
Removes stripped, rusted or painted nuts/bolts that cannot be gripped/removed by ordinary tools. Includes removers #1 through 13.
Versatile, fast and simple to use
Exclusive through-hole design so removers fit over long studs
Made from high carbon steel with hexagonal flats
Spiral flute design inside grips the nut/bolt and allows the user to remove it
Fits standard hex sizes 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8 and 11/16 in.
Fits metric sizes 8, 10, 11, 12, 13, 14, 16, 17 and 19mm
These things took out 2 18mm bolts I had that were ROUND not damaged these things were round. Thank God for this GENIUS. THIS IS A MUST FOR ANYONES TOOLBOX.
Check out the sears website and look for the BOLT OUT tools. NOT THE SCREW-OUT
P.S. AKFord: That didnt sound right, but it is quite funny!
>through 13.
>studs
>user to remove it
I read this over and over and every time I read it my head is haunted with the sound of the tool miester himself Bob Vila
There are tips here in the Garage forum for dealing with other types of broken bolts, studs, and even broken off easy outs. It looks like this tool is meant to take the place of a conventional "nut cracker" and would fit in locations that a nut cracker would not.
Sears Item #00952162000
Mfr. Model #52162
I wonder who the manufacturer is?
This is the large 13pc set for $40
There are two 5pc smaller sets available, one has a plastic case that has room for the other set also, They are $20 each
I don't know what the "other" 3 pcs are...
I will get a set of these AND the screw outs. The screw outs look like they would work well. I have used left handed drill bits for screw outs but they tend to drill. I have also ground an old broken drill bit shank into something like the screw outs and it "worked" but the angles were not quite right.
Mark
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5362&.jpg
Ford started it; Ford will finish it!
5pc Twist Out Set
Damaged Nut And Bolt Removal Set
Your Price: $35.95
Grainger Item#: 3LE67
Manufacturer: KD TOOLS
Mfg. Model#: 3537
According to the picture it looked like they had more gripping teeth than the Craftsman units. For the price of this 5 piece set you can get the big set from Craftsman. KD Tools are often available at parts houses.
