10k question..
Old Mar 14, 2004 | 12:28 PM
  #31
jamesbfishin's Avatar
jamesbfishin
I ran the truck with resistor removed, turned the truck off, unplugged the ICP. Turned the key to on and no light, did this a few times to makes sure. I'm at a loss? I also tried the resistor a few times starting fresh each time and same result. I am not giving up yet. I will try a new resistor tomorrow when the weather is warmer just in case it is defective. Thanks
Old Mar 14, 2004 | 01:59 PM
  #32
Go Aweigh2452's Avatar
Go Aweigh2452
I doubt a 1 ohm resisitor would be bad. Use an ohm meter. If you don't own one then Stop by your local NAPA and they should check it for free anyway.
Old Mar 26, 2004 | 02:27 PM
  #33
Ford_Forgotton's Avatar
Ford_Forgotton
Amazing where my webpage pops up. Good thing I have tracking
The "basic" 10k mod is just a resistor shoved under the dust seal, and the wire leads inserted into two of the three connectors. This fools the computer into thinking that the oil pressure is LOW and bumps the HPOP up a little. More pressure creates better fuel injection into the cylinder. Downside is a slight idle increase, and possible "rough" idle. Especially if you get into the lower number resistors like the 3.9k or 4.3k resistors.
Next step up is to put the mod on a switch or some kind. It can either be on/off, or attached to your throttle pedal, or tied into the Idle Validation Circuit.
Next is the "adjustable" mod. Find a 0-10k ohm variable resistor and wire a 3.9k resistor to the center tap. This gives you 3.9k to 13.9k of adjustable mod. Some variable resistors even have an OFF position.
Finally, you have the 10k Diode Clamp mod. This does not use a 10k resistor, but gets its name from the original 10k design. The CORRECT diode clamp mod will require you to CUT one of your wires on the ICP. If you dont want to cut anything, contacy Sean @ SP Diesel and he will sell you one set of male/female connectors to create your own MODULE.
WARNING: While the simple 10k mod is pyro safe (I cant break 1100 degrees with mine pre-turbo temp), some users haev reported that the lower 3.9k type mods and the Diode Clamp mod run HOT. Therefore, if you do NOT have gauges, I do NOT recommend using low resistors or the Diode Clamp.
The guy who came up with the Diode Clamp mod is Named Fred/Toptunr on a webpage called freeautoadvice.com or something like that.
Daryl
www.forgotton.net
Old Mar 28, 2004 | 09:37 PM
  #34
bartender's Avatar
bartender
Is this modification better than a "programer"? It sounds like it maybe with the increase in fuel milage. Jonathan.
Old Mar 28, 2004 | 09:40 PM
  #35
Ford_Forgotton
No. programmers are the way to go, and chips are the next step above that. 10k mods (or diode clamp mods) are just cheap feel good mods until you pony up the cash for a real HP mod like a programmer or chip.
Old Mar 28, 2004 | 11:59 PM
  #36
farmb0y's Avatar
farmb0y
Originally Posted by ROK31_99PSD
Try Here
I am new to this so tell me if the link doesnt work. Good luck.
Thanks for that link, it helps out a lot with understanding how to install the mod. I've been wanting to do this mod and have been reading about it but still had trouble understanding how it is set up. Those pictures are a great help as I am a visual learner.
Thanks!!
Pheadrus
44
Jan 12, 2014 12:45 PM
Piolet
Feb 17, 2011 11:45 PM
BigJim_610
Dec 3, 2009 09:10 PM
biz4two
Electrical Systems/Wiring
Oct 5, 2005 01:35 PM
epos48
Jan 24, 2005 02:09 PM
