1977 302 pinging/ppredetination
Old Feb 26, 2004 | 07:36 PM
SgtMaj's Avatar
SgtMaj
My 1977 F100 302 2bl is pinging almost all the time. I have changed the vacum advance, put higher octane fuel in and I canot stop it. Any one have any ideas for me on how to fix this I\i would greatly appreciate it.
Old Feb 27, 2004 | 07:59 AM
351 power's Avatar
351 power
You might try looking for alot of wear in your distributor that allows erratic spark advance. Maybe carbon on your pistons too. Hope this helps.
Old Mar 3, 2004 | 01:58 PM
jimcope's Avatar
jimcope
egr valve
Have you fixed the problem? If not Mine had the same problem. I checked the timing and it was a little high. Also check the EGR valve. That is supposed to inject a small amout of exhaust gas into the combustion chamber to stop exactly what yours is doing.
Old Mar 3, 2004 | 10:36 PM
fordeverpower's Avatar
fordeverpower
you better check your inital, mechanical, and advance timing. You won't want any more than 40 degrees total timing. Sometimes stuff wears in the dizzy as said above and the timing is then outta wack. I bet you have to much timing.
Old Mar 4, 2004 | 05:27 AM
SgtMaj's Avatar
SgtMaj
Matt and All,
Well I used the MP-3 in the my 302, yes a bunch of smoke and carbon came out, changed the spark plugs and took it for a ride, it is still pinging. I ordered a distributor yesterday (stock) I will put it in on Saturday, I will let you know what happens.
I have another question can you or anyone else, direct me how to find a picture or a vacuum diagram of a 1977 Ford F100 Custom’s 302 2bl motor so I can see how the vacuum lines hook up. I would prefer a Polaroid or some kind of photo with the air cleaner off.
Thanks to all
SgtMaj
Old Mar 5, 2004 | 03:37 PM
fordeverpower
i had the pinging problem once and had bought the crane advance piece but it didn't work so i bought a new reman dizzy and set it to 10 bdtc. the trick part was that i put the bolt in and the truck ran good but when i had tightened the bolt all the way down the timing went off a gear so I had to advance it one tooth so that when I tightened the bolt I was right on.
Old Mar 6, 2004 | 09:47 AM
WALJON's Avatar
WALJON
Thats an old truck how many miles? if lots, mabe time for a timing chain?
Old Mar 6, 2004 | 02:09 PM
daerhldgs2's Avatar
daerhldgs2
are you sure that you have preignition? Have you read your plugs -do they have very small bits/***** of silver colored material on them - that is a sure sign of preignition/detonation , if your timing chain is worn that retards your valve timing and your ignition timing and shouldn't cause your problem , possibly a cracked exhaust manifold, most engines don't have preignition all the time and normally if they do they also run hot - is youtrs?
Old Mar 9, 2004 | 08:05 PM
jade79's Avatar
jade79
My 79 302 pinged bad when I was in high school. The problem I found was the aluminum plate under the carb that the egr valve is bolted to was cloged shut with carbon. Once I cleaned the ports out, the problem was drastically reduced. Higher octane took care of the rest.
Old Mar 11, 2004 | 05:46 PM
Jag Red 54's Avatar
Jag Red 54
You said that you changed the plugs. What did the old plugs look like? That's the secret to diagnosing these things. Rich, lean, blistered? Before you spend any more money, have you tried ckleaning out the carb? Also, the plugs that you took out. Were they running well at some point in the past and just starting pinging? Maybe a cooler plug could have been the answer? Just some questions that might make it easier for someone to come up with a solution to the problem. Good luck, John
david00f150
Jun 28, 2009 08:11 PM
pursugr
Modular V8 (4.6L, 5.4L)
Sep 28, 2007 05:24 AM
Mud Bone
32
Aug 19, 2006 10:49 AM
samo
May 18, 2004 06:58 PM
Bigred77
May 13, 2003 07:11 PM
