transmission or shifter?
Old Feb 21, 2004 | 02:42 AM
Janurism's Avatar
Janurism
I've got a 1970 ford f250 ranger camper special. It's got the 390, with an auto transmission (not sure what type of tranny) . Had it parked all summer, checked all the fluids (tranny tends to lose a little over time, not much, about half a quart every few months) Column shifter; every gear all of the sudden is drive (P, N, R, etc) all try to push it forward.
So here's my dilema, is it the transmission, or the shifter? any suggestions? thanks! You guys are the best in honest advice!
EDIT by FTE:
just a note; tranny didn't catch or grind, and would work and shift smoothly while in drive, that's why i'm a little confused!
-J
Old Feb 21, 2004 | 08:29 AM
greythorn3's Avatar
greythorn3
maybe somthing is stuck in the valve body form sitting. try putting a little brake fluid in the transmission, see if that helps
Ray
Old Feb 21, 2004 | 08:30 AM
TruckDrivinFool's Avatar
TruckDrivinFool
Have you checked your shift linkage? Do you feel it engaging the detents when you move the shifter?
Old Feb 21, 2004 | 02:23 PM
Janurism's Avatar
Janurism
I have a feeling it may be the linkage, the points are rusted, and the body has settled... it's had the same old heavy camper on the back since the truck was new I think, hehe, ancient. I'm hoping it's not the transmission, the linkage would be cheaper to fix. The shifter slides, but it doesn't really feel like it is fully engaging sometime. Neutral isn't truly neutral, and it still moves in park, when I put it in drive, it takes it a second to engage when I hit the gas, but then after that there is no lag.. but it doesn't sound or feel like the tranny is slipping, I unfortnatly know that feeling from a previous vehicle...
Old Feb 21, 2004 | 04:39 PM
Torque1st's Avatar
Torque1st
Posting Legend
Put in a can of sea foam tranny conditioner.
Old Feb 21, 2004 | 05:10 PM
ranger429's Avatar
ranger429
I agree with the valve body
Brake fluid: note he said a little, too much and you will swell the seal's up to much and you will have major leaks
Old Feb 22, 2004 | 12:32 AM
Janurism's Avatar
Janurism
So how much is too much?
Old Feb 22, 2004 | 12:52 AM
Torque1st's Avatar
Torque1st
Posting Legend
How much??? -That is why I buy the Sea Foam conditioner and follow directions.
Redneckryder
Jan 30, 2011 11:45 PM
raymondvillain
1983 - 2012 Ranger & B-Series
Apr 25, 2010 09:16 PM
mike_rockwell
Jan 15, 2010 05:52 PM
irocknrol2
Oct 17, 2006 10:20 PM
bliltzerman
Nov 28, 2003 05:21 PM
