What size alternator?
Old Feb 18, 2004 | 07:18 PM
Beast12's Avatar
Beast12
I think I may have to replace my alternator in my truck. I was just wondering what size alternator I should get. My truck has a 5.0 L V8 (EFI). It does not have air conditioning. It is just a barebones truck with no high current pulling accesories. It does have a 1000 cold cranking amp battery.
I went to Ford and they said they had a 60 amp alternator listed for my truck. Is this the right one? Also, the voltage regulator is external on 85 F150's right? Because that makes a big difference.
Thanks
-Matt
Old Feb 19, 2004 | 01:55 PM
85F_150driver's Avatar
85F_150driver
yes it is a 60 amp externally regulated as long as no one else has mucked with it.
Old Feb 19, 2004 | 04:01 PM
bremen242's Avatar
bremen242
Its either 60 or 65 amp. they also have came 40amp too, although I don't know what you'd do with that.
Old Feb 19, 2004 | 05:12 PM
82F100SWB's Avatar
82F100SWB
For an 85, an internal regulator alternator is possible. Quick way to tell, an external regulator alternator has 3 wires going to it, and the regulator is on the pass. fender.
You can just see it in this picture, it's the grey box on the fender, between the solenoid and battery.
For an alternator, a good rule of thumb when replacing is to get the biggest one you can without having to modify any wiring.
Old Feb 19, 2004 | 09:22 PM
bremen242's Avatar
bremen242
cool.. I didn't know '85s could have internals.. btw, nice vice-grip battery clamp..
Old Feb 20, 2004 | 05:52 AM
82F100SWB's Avatar
82F100SWB
Nothing short of the finest in anti-theft technology here...
The internal regulator alternator was a running change, I have seen 85's with and without them.
My F250, well, it's an 82 cab on an 86 chassis, and I just plugged the internal reg. alt. harness into the 82 cab harness... So, it's really possible for any 80-86 to have an internaly regulated alternator.
Old Feb 20, 2004 | 11:30 AM
Beast12's Avatar
Beast12
Thanks for your help guys. I was asking the question because I thought I would need a new one but I guess I don't. I fixed my problem. See here ---> https://www.ford-trucks.com/forums/s...hreadid=206636
-Matt
P.S. I should have guessed on a truck this old that it would be the wiring!
mcampbell545
Oct 15, 2013 04:37 AM
Saxon
Sep 30, 2013 02:44 PM
JonArmy
Feb 2, 2013 07:54 PM
96f150
1997 - 2003 F150
Dec 5, 2009 03:50 PM
Beast12
Electrical Systems/Wiring
Feb 20, 2004 01:20 PM
