So heres the situation - I have an 85 F150 with the 300 I6, and it's slowly becoming a bit of an offroad rig. With offroad comes the demand for more electricty (i.e. lights, winches, etc.) does anybody know/and or have done a swap to a higher output alternator? If so what did you use? I'd like to find something that will "bolt right up" that'll be over 100amp, but i'm having trouble finding one.
No trouble finding a third generation 130A alternator from a '90's Taurus or Sable.
You will need to modify the regulator harness and add a heavy gauge charging cable with fuse to handle the additional current.
This has been discussed hundreds of times.
There are many threads on the "3G Swap"
Check the stickies at the top of this section and the '87-'96 section too.
x2 on the 3g alternator, one of the easier upgrades you can do to your truck. I put the 130 amp on mine, only took about an hour to put it all together.
Remember also there are different ways to accomplish the same thing, sometimes better ways. Like keeping your stock alternator, or upgrading it only slightly, and using a isolator and a second deep cycle battery to run your winch and other things. Advantages to this are;
1, You do not have to run the engine while using the winch and other things.
2. Your electrical "toys" will never run down your regular battery so your regular battery will always be fresh to start the engine.
3. You can get by with using your regular alternator.
Thanks, Matt
I would recommend a ammeter/voltmeter mod. I've been running it for a while and I couldn't be happier with how my gauge reads now.
I have had good luck with the '3G' alternator swap as well, though I used a mid 90's Mustang application. All I had to do to make the alternator physically work was tap one mounting ear for the 3/8-16 bolt for the adjustment, and get the right pulley and spacer to use a v-belt. You can get everything you need from these guys: http://www.google.com/url?sa=t&rct=j...dtcm3qtRy-OlBw
I know Gary Lewis got this and he was very happy with it.
My '87 came with a voltmeter, so I never had to worry about melting my ammeter.
Yes I did have Rocketman rebuild a couple for me. I put one on my 86' and will eventually get my '85 converted. Great concept and pretty reasonable too.
