Oil & Lubrication
Interesting Article Explaining Oil
Old Feb 28, 2004 | 01:51 PM
marklawrence's Avatar
marklawrence
Hi J,
I don't hate people in a debate.
I'm a bit confused by your friend's post. A quart of oil is a bunch of mineral or synthetic base stock plus additives. The base stock is typically about 85% of the quart. He seems to be saying the additives are 99% of the quart; of course this is incorrect. There's obviously some mis-communication here, as your friend is obviously no dummy.
I wrote the thing about 37wt, which I came up with by interpolation. I'm well aware that viscosity is measured in Stokes or Pascals, it even says so in my article. I'm also aware that weights refer to a range, there's a table in my article. Curiously, these days we see a lot of oils rated as 0w and 5w, but I'm completely unable to find a specification for these viscosity ranges. I've been presuming that there is no agreement on a spec yet, and individual companies are simply making up the ratings, again by extrapolation. If they can, I don't see why I can't.
The API (American Petroleum Institute) says the 10W portion refers to the viscosity at 32 degrees farenheit, I'm simply quoting them. It's clear to me that a lot of smaller companies make up much of their data as they go - just last year the API sued two companies for putting the API seal on their oils without API testing or the API contract.
I'm not an oil engineer nor a chemical engineer, and I've no doubt I have much yet to learn about oils. If your friend would choose to correspond with me, I'm sure I would learn something and improve my article. However, the response you quoted above which was made after skimming, not reading my article is not all that helpful to me.
cjharmon
2004 - 2008 F150
15
Jul 10, 2008 11:58 PM
BNGOD
Oil & Lubrication
Nov 15, 2007 02:00 PM
jschira
Oil & Lubrication
53
Jul 8, 2004 03:27 PM
ron96xlt
Oil & Lubrication
Mar 8, 2004 10:16 AM
78fordman
Oil & Lubrication
Mar 6, 2004 04:35 PM
