Oil & Lubrication
Interesting Article Explaining Oil
Old Feb 17, 2004 | 08:02 AM
jschira's Avatar
jschira
I was surfing and I found this very informative article about oils. It explains Group I-V oils, dino, syn, semi-syn.
Not written by any vendor, just a guy who did a lot of research.
http://www.brainmaker.com/ST1300/Oils1.html
Old Feb 17, 2004 | 07:53 PM
FordFadgeole's Avatar
FordFadgeole
Thats a good article for someone like me who doesn't know a whole lot about the different types of oil.Most guys here know most of the information.This forum is great.I'm finding out a lot about oil that I never even considered in the past.Thanks.
Old Feb 17, 2004 | 10:49 PM
peppy's Avatar
peppy
I've read the article, as with a few other articles of this same nature.
So polymers are what make the oil multi-viscosity oil. My question..... Since an oil such as a straight 30w is not multi-viscosity, does it not have these non-lubricating polymers?
Old Feb 17, 2004 | 11:07 PM
TallPaul's Avatar
TallPaul
My understanding is that a straight weight oil, say SAE 30, does not have the polymers. It also would be limited in cold flow. For example, my Haynes Ford Truck manual says not to use SAE 30 oil below 40 degrees F ambient temperatures. This stuff would clog the oil pump on a very cold day, say maybe 20 F.
It also is my understanding that some synthetic oils acheive the multigrade rating without polymers because the oil already has a very high viscosity index. The lack of polymers (or minimized use of) probably is one of several reasons synthetics flow better in cold and hold up better in heat.
Old Feb 18, 2004 | 02:20 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
It's a good summary and I enjoyed reading about GTL (gas to liquid base oil). But it contains some inacuracy and misinformation.
The tables comparing the pour point of mineral oil, PAO and Diesters doesn't seem right. For instance it lists the pour point of Group II and III at +25 deg. F. and +20 deg. F. But I checked Chevron's data sheets and Group II 10w30 has a pour point of -31 deg. F. and Group III 10w30 has a pour point of -60 deg. F.
The article also seems to perpetuate the myth of 3,000 mile oil changes and the whole parafin/wax/sludge will kill your engine unless you use PAO or Diester base synthetic.
So while it does seem to contain some very good information, beware not to take everything it says as gospel.
Old Feb 18, 2004 | 06:03 AM
jschira's Avatar
jschira
It was written for motorcycles, so that may be the reason for the 3000 mile oil change.
The article does have some errors. Mobil 1 is a Group IV, I believe, not a Group III as stated in the article.
Delvac syn. is a Group III, not a Group IV.
The basic info, Group I-Group IV and additives, is very informative.
Old Feb 18, 2004 | 11:32 PM
100dolla68's Avatar
100dolla68
i thought it was a great article. i finally found what i was looking for . now i know of the flash point . ther you go i learn something new everyday
Old Feb 19, 2004 | 12:42 PM
TallPaul's Avatar
TallPaul
Only got to read three sections so far (refining, synthetics, and making multigrades) and I think it is pretty much right on. The table values of pour point do look wrong though. He overgeneralizes on the viscosity increase factors using SAE grades, but is is ball park. And he correctly (from what I have seen elsewhere) notes that a multigrade is better than a straight weight if the engine overheats (oil above 230 degrees). I disagree about the oil companies using cheap VIIs. Some may, but I suspect the premium oils use good ones.
Old Feb 19, 2004 | 02:05 PM
Rockledge's Avatar
Rockledge
Paul, I would be interested in looking over the sources of this information if you can recall who/what they are.
(FWIW, I'm just curious about it, that's all, I'm not taking you to task or anything... )
Old Feb 19, 2004 | 02:19 PM
TallPaul's Avatar
TallPaul
I bet I read it in Jim Fitch's book How to Select a Motor Oi and Filter (noria.com). I will check tonight and post what I can find. It also was his book that said not to use a straight weight if your engine overheats--I don't understand that, you would think the polymers would cook before a straight oil. Maybe I will pose that question to MolaKule at the oil guy site.
I am glad you put the FWIW. We all should be willing to take flack and perceived flack lightly on these boards since the posters may not mean it. I think few of us ever want to offend anyone, just clarify and ask good questions.
Old Feb 19, 2004 | 09:59 PM
TallPaul's Avatar
TallPaul
Permanent viscosity sheer down "is a non-issue for some Group V synthetics and only a marginal issue for Group III and Group IV base oils. Some synthetics don't use VII for 10w30, 15w40, 5w30, but do use them for 0w30. The exception might be a Group V ester synthetic which can reach a 0w30 unaided by VIIs."
From "How to Select A Motor Oil or Filter for Your Car or Truck," by James C. Fitch.
BTW, I have read this book three times and guess I will read it again. A hard copy is $5 more than an online copy, but the hard copy is nicer and has a beautiful front cover showing a hand removing an oil drain plug with the black oil running down the guy's arm.
Old Feb 27, 2004 | 02:28 PM
Texan1983's Avatar
Texan1983
so would i be ok with running that 5w40 syn rotella T in my truck? looks like a great oil.
Old Feb 28, 2004 | 01:00 AM
marklawrence's Avatar
marklawrence
Hi guys,
I wrote the article in question.
It was written very much with motorcycles in mind. Motorcycles generally run the engine oil through the transmission; this is hell on the VII package. I test the viscosity of oils regularly, and normal motor oil does not hold up in a motorcycle for more then 2500 miles. This statement is not true for cars - I run my engine oil in my (eh-hum) Brand "C" pickup truck for 7000 - 9000 miles.
The pour points listed are for pure base oils, and are correct. I work hard on my research - I'm a part-time graduate student in physics, bad research is simply not tolerated. The oils you buy are a blend of a lot of stuff, and normal multi-grade oils have typical pour points of -10 or so.
I stand by my statement that Mobil-1 is now primarily a group-III oil. Since the Exxon buyout and their lawsuit with Castrol, Mobil-1 has turned into just another group-III blend. It's still a good oil, and I don't hesitate to recommend it, but if you want a pure synthetic base stock you're currently limited to AMSOil and Motul-5100.
A straight 30 weight oil would have no VII package, no polymers to shear. This oil would be perhaps a good choice in the summer in a southern state, but a very poor choice if you think you might ever start your engine in temperatures under about 45 degrees.
Rotella is a fine choice for truck motors. Mobil-1 is about to release a 5w-40 oil for "SUVs" which I expect to also be excellent.
PAO and Diester based synthetics have a VII package. These base oils have a significantly higher VI than group I or group II oils, and require less of a VI package, but it's there.
VII packages definitely come in different prices and different qualities. Spiffo-Magic 10w-40 for $1.09/qt has a package which is very much inferior to the package in, for example, the group-II Rotella or Delvac 15w-40 oils. However, truck engines are really not all that hard on the VII package, this is considerably less of an issue than in a motorcycle.
I write and sell computer software; I manufacturer and sell aerodynamic accessories for motorcycles; and I maintain a motorcycle information web page http://MotorcycleInfo.calsci.com. I don't sell motor oil, and I don't sell truck parts or accessories. To the contrary, I buy my oil filters (Purolator Pure-One) by the case at Pep Boys, where I insist on a 25% case discount, and I buy my oil (Rotella 5w-40) by the case at Wal-mart, where asking for a case discount is about as effective as lecturing on Buddhism in Sanscrit in Saudi Arabia.
I run Rotella 5w-40 in all my motorcyles, my 5.3l truck, and my 7.4l motorhome.
Old Feb 28, 2004 | 03:25 AM
horsepuller
FTE Emeritus
Hi Mark! Thanks for joining us at FTE!
I was wondering about the pour point comparison in your paper. Would those numbers for mineral base oil be reflective of a Group I oil? Average pour points of -10 seems kind of high since I've gotten used to seeing product spec's with lower pour points. It seems that a Group II or III oil should have a much lower pour point, such as I quoted from a spec sheet in my previous post. It just didn't seem to be fair to compare the highest rated (IV, V) pure synthetic against the lowest rated (I) mineral oil.
Old Feb 28, 2004 | 06:09 AM
jschira's Avatar
jschira
Originally posted by marklawrence
Hi guys,
I am not challenging you work, just trying to get accurate information. So please don't hate me.
I posted your article on another forum. Below is the response that I got from someone who has worked in the oil industry about 30 years, including a long stretch as an oil blender:
Sorry I dont have time to read all of the article (panic to get 450 ready for a job), but there were a lot of inaccuracies in the scan of the first half.
To begin with, the referrence that 85% of lube oil is base oil is one I see quite often. This is absolute malarky. Something around 1% by mass (depending upon viscosity modifier required) is the truth. The number he uses comes from blenders who buy their additive packages pre-mixed, which means that the additives are mostly base stock used to suspend the actual addtives. Most serious manufacturers (and several boutique blenders) buy their VM raw (dry polymer), and some even have colloidal mills to do some of the additive chemistry from scratch.
His reference to measuring viscosity at 32 deg. F is also very wrong. The first number in the SAE grading system is the viscosity RANGE (not point) at 100 deg. F (40 C). This is why pour point and cold cranking vis tests are so important. The W means that there are some pour point additives or base oil charactaristics that address the lower temps. The anecdote about the guy meauring his motorcycle oil vis as 10-37 is very telling - there is no such thing as a 37 weight, only a range nominated as 40 that includes a wide range of actual viscosities. The issue of shear-down though is quite real. This is where blenders can cheap out on the viscosity modifier and still be in grade after blending. I have seen many oils shear down out of grade, and it always happens in the first few hundred miles, after which the VM shear down rate is very low until some set point (for Castrol GTX 20W-50 sold 30 years ago, it was about 3500 miles in an air cooled VW), after which it fails in a big way. This is the reason I cannot support ridiculously long (or short) drain intervals.
There were a lot of others, but overall, he does a good job of painting a general picture of the hows and whys. Just dont view any specifics from his article as technically accurate.
