1978 - 1996 Big Bronco
alternator
Old Feb 15, 2004 | 05:05 PM
Black Ford XLT's Avatar
Black Ford XLT
alternator
Has any one ever installed a 200 amp alternator from j c whitney.MEAN green is the name brand TR
Old Feb 15, 2004 | 05:43 PM
tite4x4's Avatar
tite4x4
no. but I have one installed from Powermaster
Old Feb 15, 2004 | 07:15 PM
AYoungblood's Avatar
AYoungblood
A 200Amp'er? 3U?
Where did you get the harness to convert it?
Thanks,
Adam
Old Feb 16, 2004 | 12:33 PM
tite4x4's Avatar
tite4x4
Hey Adam
The Powermaster Alternator that I have installed on my rig is their 200 Amp unit. They do have other units, with lower amperage, that will fit into the Bronco's. Check out their web site at http://www.powermastermotorsports.com/
I did have to change the wiring a little. The stock alternator has two connectors pluged into it, and the powermaster only uses one of the two connectors. But it was all pretty self explanitary. If there is any technical issues with the installation, Powermaster is more than happy to help out with the installation.
The only other wire that I had to purchase was another battery cable to connect between alternator and solinoid that's mounted on the fender.
If you plan on adding a second battery then you would also need the battery isolator that maches the alternator that you get. If you try to order the dual output alternator, instead of getting the isolator, then you would need to change the brackets that hold the alternator.
As far as where to get the powermaster units, check out their web site to find out where there is a local parts store in your area. They might be able to sell it to you directly.
Hope this helps
Old Feb 16, 2004 | 09:14 PM
BroncoRoadKill's Avatar
BroncoRoadKill
I have had too fix too many of those power master crap.
They cut too many corners too make as much money as they can.
Also, the isolation diods don't have too be matched too the alt. They just have too be able too handle the amps. 200A. alt.=400A. diod.
Old Feb 17, 2004 | 09:14 PM
92GT5ohRed's Avatar
92GT5ohRed
I surf the Mustang boards a lot and the biggest name on the mustang boards is PA Performance. www.paperformance.com I think. They are in all the mustang magazines, 100% new and lifetime warranty. I saw them on www.fordmuscle.com too with a tech article
ConvertedFord
Oct 3, 2012 06:34 PM
lartross
Jul 28, 2012 03:48 PM
powerstroke1869
May 6, 2011 01:44 PM
Riso79
Jun 25, 2002 01:08 AM
