Need alternator setup
Old Oct 3, 2012 | 01:44 PM
ConvertedFord's Avatar
ConvertedFord
Looking for dual alternator pulleys n bracket for 2005
Old Oct 3, 2012 | 03:46 PM
bpounds's Avatar
bpounds
Are you looking for pull parts from somebody? Or just need part numbers? Are you aware of the Ford bulletin for converting to/from dual alts?
Old Oct 3, 2012 | 04:09 PM
ConvertedFord
I need both and I'm not aware of a bulletin
Old Oct 3, 2012 | 04:27 PM
bpounds's Avatar
bpounds
Sorry, I can't find the bulletin that I thought existed. There is one for the 6.4 and the 6.7 to add or subtract the second alternator. But all I can find for the 6.0 is how to remove it. Doesn't help you.
Old Oct 3, 2012 | 04:59 PM
ConvertedFord
K thanks. U have part numbers
Old Oct 3, 2012 | 05:06 PM
BLADE35's Avatar
BLADE35
Why dont you just get a Preformance alternator
just seems like a Big Hassel to convert to dual alt setup Need the wire Harness and computer flashed in addition to pulleys and brackets
A preformance alt will do what you want I would assume
Old Oct 3, 2012 | 05:10 PM
bpounds's Avatar
bpounds
No, it didn't have part numbers. I suspect that some of it would be the same as 6.0. But my guesses don't help you.
And I agree with Benny. Spend the money on a high output DC Power instead, would be my suggestion.
Old Oct 3, 2012 | 05:39 PM
BLADE35's Avatar
BLADE35
https://www.dcpowerinc.com/
One of the best you can get^^^^
Old Oct 3, 2012 | 06:01 PM
davidkstyler's Avatar
davidkstyler
...and fewer belts, fewer moving parts, better idle output.
Here is one bulletin which is enough to scare me off dual alternators!
https://www.fleet.ford.com/truckbbas/non-html/Q91.pdf
Old Oct 3, 2012 | 06:04 PM
ConvertedFord
Didn't see anything there for ford under dual kits
Old Oct 3, 2012 | 06:34 PM
davidkstyler
Why do you want dual alternators? If it to get higher output then the DCPower alternators can take you up to 300 Amps. They are built heavier than the OEM alternators and have an excellent reputation here.
One thing to remember is that the factory wiring is sized for 110 Amps IIRC. When you increase the alternator output you have to increase the alternator/battery and the battery/ground wire size so you don't melt them.
allingeneral
Aug 22, 2015 09:45 AM
brandon.edwards
Sep 1, 2013 12:27 PM
buckweet1980
Aug 21, 2007 01:59 PM
