Floating Wrist pins
Old Feb 13, 2004 | 06:33 AM
snowfighter's Avatar
snowfighter
Floating Wrist pins
I am starting the build up of a play motor I am wanting to use KB uem-kb177030-8 They are 351c flat tops @ 9.5 to 1 well they come with floating wrist pins in which I would like to use but I do not know if I can considering I have to put bushing in the rods. What do you all think?
Old Feb 13, 2004 | 09:13 AM
67 F250's Avatar
67 F250
When you bush the rod you usually do use floating pins.
Old Feb 13, 2004 | 12:07 PM
monsterbaby's Avatar
monsterbaby
well the only set of KB pistons I have bought (were for a 302) came with the locks for floating pins, and I think you use the same pins as the pressed as they are only pressed into the rod but already float in the pistons
Old Feb 13, 2004 | 09:57 PM
David10's Avatar
David10
Here is a pic of a bushed rod and the KB149 we used. The only problem we have is with axels.
Seriously .. They work just fine. The Kid drives it like he stole it every day.
Old Feb 15, 2004 | 08:53 AM
snowfighter
Hey Thanks all I think this is the way I'm going to go.
David You wouldn't happen to have a pic of a completed rod and piston ?
Thanks Wayne
Old Feb 15, 2004 | 09:33 AM
David10's Avatar
David10
Snow Fighter:
Here is all I have. Hope this helps. Shows the spiral keeper.
Here is a top view after fly cutting the pistons for the .560 lift and before cleanup of the sharp edges.
More shots of the rod end.
Old Feb 16, 2004 | 09:30 AM
snowfighter
David Thanks for the pics
Wayne
94iditpuller
20
Dec 9, 2015 08:42 PM
Beamed
Mar 28, 2009 10:03 PM
hunkajunk68
Mar 12, 2006 07:25 PM
Leonard Bode
Mar 25, 2004 04:13 PM
Old Blue Crew
Sep 3, 2002 01:59 PM
