Wacky Mouse +
Old Feb 12, 2004 | 04:00 AM
Timken's Avatar
Timken
Wacky Mouse +
I have Home XP..........the other day the scroll bar at the right of the page I was on would not let me put the mouse pointer on it to move it, it would just jump away also sometimes when I read a page I have seen the pointer move across the screen on it's own. Anyone else have this happen?
Old Feb 12, 2004 | 04:16 AM
Jimmy Dean's Avatar
Jimmy Dean
Optical mouse? if so, my g/fs roomate, her mouse randomly jumps across the screen.....thenagain, it may be a virus, her comp is rather full of them, and AdWare
Old Feb 12, 2004 | 04:44 AM
Timken's Avatar
Timken
Wired mouse, got Norton, Ad-aware, iClean....just getting strange. I've also lost the task bar that is at the bottom that shows the green squares to show you how much is loading...?...
Old Feb 12, 2004 | 05:07 AM
Torque1st's Avatar
Torque1st
Posting Legend
Sometimes a broken wire in a wired mouse cord can cause problems like you describe.
Old Feb 12, 2004 | 05:25 AM
Jimmy Dean's Avatar
Jimmy Dean
Yes wired, but does it have a ball? or an optical on it? The red light oin the bottom?
Old Feb 12, 2004 | 05:56 AM
Timken's Avatar
Timken
Dell mouse...cord with wheel , two buttons. I put the status bar back on and sometimes it just gets taken off every now and then but I don't do it. Sometimes it has a mind of it's own.
Old Feb 12, 2004 | 06:16 AM
jor's Avatar
jor
If it's a ball type mouse, take the ball out and clean it with detergent and hot water. Clean the rollers inside the mouse with alcohol. Put it back togher and see what happens. If it's an optical mouse, reinstall the software? Good luck.
jor
Old Feb 12, 2004 | 06:29 AM
Timken's Avatar
Timken
I clean it quite often, thats why it does not make any sense. I first thought of a spider or other small bug I pop out the ball and use air hose + clean by Q-tip and alcohol.
Old Feb 12, 2004 | 02:46 PM
grapegravy's Avatar
grapegravy
Is this only happening in the Internet Explorer windows? If so, do a repair on the installation. Go to add/remove and click on IE and then remove. Another box will come up asking if you want to remove/change/repair.
ford2go
Aug 29, 2016 10:18 PM
Eddiec1564
Site Announcements
77
Aug 21, 2013 12:59 PM
Beerstalker
Dec 15, 2007 10:38 PM
cdrmotorsports
21
Jan 24, 2007 07:44 PM
