Having trouble with Windows Update, anyone else?
Old Dec 15, 2007 | 12:13 PM
Beerstalker's Avatar
Beerstalker
Is anyone else having trouble with the Windows Update website? Whenever I go there on my parent's computer I keep getting error code 0x80072EE7, and it will not load.
I've tried following all the instructions I can find about the error that talk about turning on different ports in the firewall and making sure the update website isn't in the host file (no websites were in it).
Actually I started looking around and I can't even get to the Microsoft home page, or Windows home page. (www.microsoft.com, or www.windows.com)
All other websites are working fine (that's why I'm able to post this question).
Old Dec 15, 2007 | 12:35 PM
lenny1carl's Avatar
lenny1carl
Beer, i just chk'd both of mine(1, a 1999 Compaq Presario PC, and the 2006 Toshiba LT) both are getting updates.
are your validation tools current. i'm not a computer expert, but if there is a lapse...
Old Dec 15, 2007 | 02:22 PM
donjamer's Avatar
donjamer
When you checked the host file did you scroll down?
Sometimes it will look like there is nothing there, but it is way at the bottom.
Also try adding the microsoft site to your trusted sites..
You can also try PINGING the microsoft site from the command prompt to see if you are even reaching the page.
To Ping (If you do not know how) is to
Goto Start
Run
Type in CMD
when the black screen appears.
enter Ping www.microsoft.com
You should get a reply.. If not then that is the problem..
Old Dec 15, 2007 | 09:45 PM
Nitramjr's Avatar
Nitramjr
I have been having a problem with updates for a while. I get the little popup telling me updates are available, go through the whole update procedure, restart and get the popup. After going through the process a bunch of times I finally disable automatic updates. Problem hidden but not solved.I also lost the use of System Restore at some point. I hate to reload windows but may have to at some point unless there is a way to reinstall just that.
Old Dec 15, 2007 | 10:38 PM
donjamer's Avatar
donjamer
You can also try registering the DLL's
Go to Start, Run, type in
net***** stop wuauserv
Click OK
Reregister these files from Start, Run, type these in and
click OK or press Enter after each one :
regsvr32***** wuapi.dll
regsvr32***** wuaueng.dll
regsvr32***** wuaueng1.dll
regsvr32***** wucltui.dll
regsvr32***** wups.dll
regsvr32***** wuweb.dll
regsvr32***** MSXML3.dll
net***** start wuauserv
ON EDIT: enter a period then exe for the asteriks above..
I guess the software doesn't like the command
4444me
Site Announcements
Apr 7, 2013 03:17 PM
bobj49f2
Sep 10, 2009 08:05 AM
cjben
Jun 20, 2009 09:54 PM
1956MarkII
Aug 6, 2008 06:57 AM
pancake
Oct 28, 2005 12:51 AM
