column wiring question?
Old Feb 11, 2004 | 06:47 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Kent,
I think you may be on the right track. The last GM column I worked with was a 79 Oldsmobile tilt and it seems to me that the big wires that brought in the power were on the lower end of the column near the neutral safety switch and the switch was activated with a rod like you described. Perhaps 82-up columns were totally different. I haven't worked with a GM column later than 79. I agree that the wires on the connector sandimasguy pictured look too small to power the column. They appear to be wires for directional signals or something similar that would carry lower amperage current.
Surely someone can weigh in to help sandimasguy out that may have worked with the later column. Anybody?
Old Feb 11, 2004 | 08:22 AM
Protozoa's Avatar
Protozoa
The connector in the picture is from the turn signal switch and wiper switch. These are not the ignition wires. A GM column uses a white switch located at the lower end of the column. It is held down with 2 small bolts. It is operated by a relay rod that moves via a rack and pinion arrangement at the lock cylinder end. I thought all of these old Saginaw columns used the same switch connector from about 1970 to 1987. Is it possible you unbolted it and left it with the donor car? Let me know if this doesn't clear thing up, I can take a picture of one on mine and send it to you.
Dave
Old Feb 11, 2004 | 11:21 AM
sandimasguy420's Avatar
sandimasguy420
thats what it ended up being is a rod that connects to a switch under the dash but we are not going to use that
we are ditching this column and getting an ididit or flaming river
thanks for all of your guys help!!
finally got to drive her last night can you say sideways and smoking them in all gears!!!! wooooohooooo
no my problem will be how to get some more weight on the rear end so i dont just burn out everytime i put my foot in it........
Old Feb 12, 2004 | 08:07 AM
GreatNorthWoods
I'n still a little confused as to what the problem was. Was something missing from the column or did you have the wrong connector? Can you elaborate?
Gigemags05
1947 and Older Ford Trucks
Nov 18, 2014 11:29 PM
Gigemags05
Nov 17, 2014 04:36 PM
chromedaddyo
Feb 16, 2004 11:26 AM
wosborn
Apr 21, 2003 02:24 PM
4starcstms
Electrical Systems/Wiring
Jan 31, 2003 06:54 PM
