Pyro probe install...
Old Feb 5, 2004 | 05:28 PM
rtalich's Avatar
rtalich
Question Pyro probe install...
I'm ready to drill and tap for my pyro probe. The probe that came with the gauge is a screw in type, no clamp. My question is, would I need to install with some kind of lock washer, or lock tight.. etc. Please advise.
Thanks,
Rob
Old Feb 5, 2004 | 09:10 PM
sagebel's Avatar
sagebel
Are you going pre turbo or post turbo? I installed mine pre turbo and used a little ultra high temp sealant and I have no problems.
Old Feb 5, 2004 | 10:58 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
If you are going to drill and tap then you want the screw in type, no sealant should be required (unless it leaks )If you're wanting to clamp it in the up pipe there should be a little set screw on the probe that allows the threaded portion to be removed.
Old Feb 5, 2004 | 11:06 PM
Ggg6's Avatar
Ggg6
Since the threads are NPT then you will not need any thread locker.
franksuek
Dec 29, 2011 05:55 PM
Joelong258
Feb 21, 2011 02:54 PM
schlepprock250
Apr 23, 2008 01:02 PM
Fxehogg1
May 13, 2007 03:24 PM
Tha50Kid
Feb 15, 2005 09:41 PM
