1978 - 1996 Big Bronco
E4OD missing third?
Old Feb 6, 2004 | 09:31 AM
Kikwear's Avatar
Kikwear
Well, I know that the speed sensor is correct. I've paced my buddy's car before and the speedo is correct with the 31" tires I have.
I know what a neutral safety switch does and my truck does not start unless it's in P or N. I didn't know it was a dual purpose sensor.
I'd be interested in changing to the updated sensor but I don't think the trans is throwing any codes. Is it checked through the normal means of the connector under the hood by the brake master?
I did find a MPLS/TR Sensor Service Kit. PN F5TZ-7A247-A. Seems to be a retrofit kit like you speak of BOJOFASO. My local Ford dealer quoted me $97.24 based on that part number.
Old Feb 6, 2004 | 01:03 PM
BOJOFASO's Avatar
BOJOFASO
that sounds about right for the MLPS and the new wireing harness. you would still pull the codes as you normally would. i believe you are looking for a stored code 67 but am not 100% sure.
salty88
Oct 20, 2012 09:38 AM
onpier5
18
Oct 3, 2012 09:44 AM
pbaxter
Texas Chapter
Oct 9, 2007 02:38 PM
bradman755
Mar 2, 2007 12:47 PM
gblakeney
Jan 27, 2006 06:43 AM
