Base timing for a 1998 5.0L?
Old Feb 1, 2004 | 07:26 PM
lamrith's Avatar
lamrith
What should my timing be at idle? I am seeing 20-24* timing which seems a bit excessive for a 5.0. My older 302/5.0 is bse timing 10-14*
Thanks.
Old Feb 1, 2004 | 07:51 PM
ric232's Avatar
ric232
Assuming your motor has a distributor (my 99 does not), you have to pull the SPOUT connector to put the ECU in service mode or you won't get an accurate reading. Once you do that, the initial timing should be 10deg. If you have a distributorless ignition, the timing is not adjustable and it is most likely okay anyway.
Old Feb 1, 2004 | 08:00 PM
lamrith's Avatar
lamrith
I found out that all the 5.0 explorers are DIS like your '99. Maybe it is fine, just seems a bit high to me. I am still researching this and will let you know. Anyone ever seen a timing adjuster for for these motors like they have for the mustangs with DIS?
Old Feb 1, 2004 | 08:27 PM
ric232's Avatar
ric232
It's not too high. If you were able to put to ECU in service mode, it would read 10 deg.
My last two Mustang GT's had distributors and whenever I check the timing on those without putting the ECU in service mode, the timing read very high and jumped around quite a bit. When I pulled the SPOUT connector, they would read dead solid on 10 degrees.
What is making you interested in the timing? Is the motor pinging? If so, you'll see plenty of threads here on other issues that are causing detonation in these motors.
Old Feb 1, 2004 | 09:27 PM
lamrith's Avatar
lamrith
Well there are a number of things. Most notibly it is hannging idle, and the idle will creep up over 1200rpm+, and not come down even with the TB closed fully. I know the cam I have in it will want to be higher than 750rpm, but something closer to 900 would be nice.
I am also having fuel issues and I think the injectors are to big which is a easy fix, but I am just dotting I's and crossing T's since I noticed the high timing.
With what you said and me messing with FP I think you are right and that it is not timing related. I dropped the FP and the motor seemed to respond better overall, so I will change the injectors back to stockers and see what happens. I had increased them since I went with a bigger cam and alum heads, guess I did not need to. The car is not road worthy at this point, so I am just testing in the garage with no load.
THANKS RIC!
Nally427
Aug 6, 2012 12:50 PM
USAF FordGuy
1978 - 1996 Big Bronco
Jan 7, 2010 01:02 PM
Fairlane466
18
Dec 21, 2009 02:37 PM
brrossi
Feb 22, 2007 01:09 PM
