1978 - 1996 Big Bronco
5.0 vs 5.8 flywheel
Old Jan 5, 2010 | 06:31 PM
USAF FordGuy's Avatar
USAF FordGuy
5.0 vs 5.8 flywheel
Just outta curiousity... for the second time Im changing out my transmission on my 89 with the 5.8 and the flywheel is bad. I have an 84 5.0 as a parts truck, will the flywheel work on the 5.8 from the 5.0???
Old Jan 5, 2010 | 07:57 PM
Conanski's Avatar
Conanski
No, same size but the 5.0 version is 50oz imbalance while the 5.8 is 28oz.
Old Jan 5, 2010 | 08:01 PM
USAF FordGuy
Thanks for the help, arg. Would going with a used one from a junkyard be ok??
Old Jan 5, 2010 | 09:14 PM
American Thunder's Avatar
American Thunder
As long as the ring gear teeth are good and there's no cracks around the bolt holes.
Old Jan 6, 2010 | 10:47 AM
Kemicalburns's Avatar
Kemicalburns
and you are infact getting the right flywheel. i dont always trust what the yards say those are. unless you physicaly see the flywheel being pulled from a 5.8
Old Jan 6, 2010 | 12:05 PM
alxsnmr's Avatar
alxsnmr
Flywheel or flexplate? They are two different things as a flywheel is for a manual transmission to which the clutch pressure plate bolts to while the flexplate is on an automatic transmission which the torque converter bolts to.
Old Jan 6, 2010 | 05:03 PM
American Thunder
You can visibly see the difference between zero oz, 28 oz and a 50 oz imbalance weights. Compare the junkyard piece to your old one, to verify the correct balance weight. If it has no balance weight at all, it's off a 240/300 inline 6, which will physically bolt up to a 302/351, but the zero imbalance wouldn't be good for the V8.
Old Jan 6, 2010 | 06:31 PM
starmilt's Avatar
starmilt
I havn't bought one in a while, but the last I think a flexplate was around was 38 bucks.
How much are they now.
Old Jan 6, 2010 | 11:48 PM
American Thunder
Last I bought a new 302 flexplate was about 10 years ago, for around $80.
Old Jan 7, 2010 | 01:02 PM
alxsnmr's Avatar
alxsnmr
Rockauto lists both the flywheel and flexplates for roughly 60 bucks, with premium flywheels as much as 90 bucks...
RustyBarnard
Aug 11, 2016 08:47 PM
Olefordboy
New Member Introductions
Feb 5, 2016 05:33 PM
fordboy97
Oct 21, 2015 08:42 PM
TheGageinator
Jul 20, 2013 12:06 AM
RustyBarnard
Aug 7, 2011 09:20 AM
