1978 - 1996 Big Bronco
'ECC tester'
Old Jan 29, 2004 | 05:25 PM
broncobillybob's Avatar
broncobillybob
'ECC tester'
i was looking under my hood and saw the 'ECC TESTER' was unhooked. it's on the left side in the corner of the firewall and left fender. what is this thing, and is it bad if a elf connected it and he can't get it undone? -wb
__________________
93 bronco xlt 351
Old Jan 29, 2004 | 07:36 PM
ALSAIR's Avatar
ALSAIR
I got to ask what did you...Errrrr, the elf hook it too?
She Ain't Revved Ti'll The Rods Are Thrown!
Al
Old Jan 29, 2004 | 08:38 PM
broncobillybob
uh.. the elf hooked the dangleling cable connectors to the receiver labled 'ECC TESTER'. there was to cables not hooked up, one was a big red plasic one w/ multiple metal inserts that go into the receiver. the other was a gray plastic one and it was a single insert connecting into the same receiver as the larger one. the ECC TESTER is made of black plastic.
-wb
__________________--
93 bronco xlt 351w
Old Jan 30, 2004 | 06:01 AM
ALSAIR's Avatar
ALSAIR
Are you driving this bronco? The E.E.C. test port is simply that, you plug in a tester and run a diagnostic on the E.E.C. The other plugs you are describing sound like fuel pump relay connections. They go into a black box attached to the air cleaner box, that is actually a housing for the relay connections. If you are driving the bronco and it is running, your lucky!! You could short something out. I am not sure if your year has 1 or 2 fuel pumps, I will check a book later and tell you what it says the other connectors are used for!
Al
Old Jan 30, 2004 | 08:23 AM
screwy's Avatar
screwy
Sounds like you just plugged them back into their cover where they should be. I'll load a pic later if need be. 93 had one in tank pump.
Old Jan 30, 2004 | 02:49 PM
broncobillybob
yeah it was just a cover. i got them apart when i was waiting to go to class. the receiver is just plastic, there wasnt any metal in it. thats a relief. but what are those cables for? they are just hanging there. at times like this i wish i had a digital camera. -wb
______________________
1993 Bronco XLT 351W
Old Jan 30, 2004 | 05:22 PM
ALSAIR's Avatar
ALSAIR
There are the E.E.C. testing port which you are now familiar with, there is also a fuel pump test plug to jump the fuel pump, atleast my 87 has it, there is a trailer light plug over there. Mine are labeled from factory. You coulda had a real nightmare on your hands had the terminals shorted. That bronco would of stopped bucking and the show would of been over there broncobillybob!
Call a good exterminator and get rid of the elf's!!!
Al
Old Feb 1, 2004 | 06:08 PM
broncobillybob
oh i ran out ALL the critters away from my truck. sorry 'bout the reply went to panama city this w/e. thanks ALSAIR!!!!!!!!
-wb
tbflyer
Feb 21, 2017 06:08 PM
1990f2505.8
18
May 27, 2016 08:17 AM
alstieg
Oct 31, 2009 04:29 PM
tmryan362
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 6, 2006 09:08 AM
matt04818
Electrical Systems/Wiring
Jun 18, 2004 07:27 PM
