vin decoder
Old Jan 28, 2004 | 04:54 PM
tastyklair's Avatar
tastyklair
vin decoder
I need vin decoder help. I have a 1979 f150 #f14hldg7525. Also on the door tag the body is "aal" the trans is "k" and the axle is "h2". Could this by chance be a highboy. Thanks
Old Jan 28, 2004 | 06:55 PM
F150daniel's Avatar
F150daniel
Model Year: 79
Series: F150 - 4x4 Pickup
Engine: 8 Cyl, 351ci (5.8L) 2bbl
Assembly Plant: Michigan Truck
black vinyl bench
C6 auto tranny
3.50 LSD gear
its not a Highboy
last year for them was 77 1/2
EDIT:
whats your front axle code?
theres a tag on your front diff, post the numbers off of it.
Old Jan 28, 2004 | 07:44 PM
Mil1ion's Avatar
Mil1ion
They didn't make Highboys after 1977.
If you want to decode the plate yourself just go to my web site and look for *Truck decoder*
Just click my ClubFTE Memeber .... hyperlink under my name.
Old Apr 3, 2010 | 03:39 PM
bogger555's Avatar
bogger555
I have vin - F15MEC0968
BODY - DU4
TRANS - G
AXEL - 15J
W.B.? - 133
The writing is wore off the bottom of the tag but on the bottom left is 6050. then 1976. then on the bottom right 172234. tag is on the firewall. 1 inch wide by 3in.
help decoding ?
Old Apr 3, 2010 | 04:27 PM
Rockstone's Avatar
Rockstone
You pulled up an old thread to post this. Here goes;
F150 2WD
390 V8 4bbl
Built in Mahwah, NJ
Model year 1976
Styleside pickup
Auto trans (C6)
3.25:1 gear ratio (non limited slip)
133" wheel base
Itsme7
Jan 3, 2011 09:22 PM
RDON
Apr 14, 2006 10:05 AM
Leadsled91
Feb 18, 2005 05:54 AM
oppy
16
Dec 30, 2003 03:18 PM
trouble
Aug 17, 2002 11:41 PM
