Vin # DECODE
Old Apr 11, 2006 | 05:12 PM
RDON's Avatar
RDON
Vin # DECODE
I would apprecate it if someone could decode this VIN # F25HKZ04551
Thanks DON
Old Apr 11, 2006 | 05:15 PM
ford390gashog's Avatar
ford390gashog
post the axle , trans and other codes.
Model Year: 77
Series: F250 - 4x2 Pickup
Engine: 8 Cyl, 351ci (5.8L) 2bbl
Assembly Plant: Kansas City
Transmission: No code selected
Front Axle: No code selected
Rear Axle: No code selected
Old Apr 11, 2006 | 05:18 PM
JLMoreno911's Avatar
JLMoreno911
What excatly are you trying to find out?
Old Apr 11, 2006 | 06:17 PM
RDON's Avatar
RDON
When I had a smog test they said this was not a CA truck so I was wondering, And would like to get the right color to repaint the bed.Other then that just like all info I could get on this truck.
Thanks Don
Old Apr 11, 2006 | 08:20 PM
Mil1ion's Avatar
Mil1ion
Get me the info off of the white sticker on the valve cover.
This identifies the engine.
The DSO code states where it was sent to.
I doubt Calif as San Jose usually builds them .
Old Apr 12, 2006 | 10:18 AM
RDON's Avatar
RDON
Engin family 351M/400
engin dis 351 CID
SPARK PLUG ASF-42 Gap .042-046
Ign tim 6 deg BTDC
TIMING RPM 650
Choke SETTING 2 RICH
FAST IDEL HIGH CAM ---
KICK DOWN 1250
CURB IDEL NON A/C 650
TSP OFF
RPM NON A/C 500 NON-CATALYST D7TE-9C485-DEA 7-423
mesureing between the heads is from what I can tell is right at 12" the thernastate in the block and the valve cover bolts are stagerd.Read some where diffrents between M AND C This motor was installed by FORD 3YRS ago.
Hope this is the info you need THANKS DON
Old Apr 12, 2006 | 01:00 PM
Mil1ion's Avatar
Mil1ion
I meant this one
but from the looks of it, It is NOT a california engine.
What is the DSO code on the door plate?
Old Apr 12, 2006 | 04:21 PM
RDON's Avatar
RDON
The only other plate is on the door itself.It is about 1" wide and maybe 3" long
WB COLOR TYPE/GVW BODY AXEL
133 M 252 DU4 38J
I apprecate your help on this Don
Old Apr 12, 2006 | 05:47 PM
Mil1ion's Avatar
Mil1ion
The next (bottom) line down on the Rating plate has the DSO in it.
Old Apr 12, 2006 | 09:34 PM
RDON's Avatar
RDON
on the left side bottom line its a gross wieght on the right side there is a DSO,But no nubers beside it. The number closes to it is 1977-76.Stright above "DSO" is a number 38 with a letter J.Hope that is what we are looking for
It looks like rivets or screws were take off the tag but it is not bent or messed up. Don't know whats going on with that.
Don
Old Apr 12, 2006 | 11:10 PM
Mil1ion's Avatar
Mil1ion
DSO code 76 is Denver.
This isn't a California truck.
It was my understanding that ONLY California based trucks (those originally built for CA) had to have the proper equipment .
Why would a 49 state truck have to convert ?
Old Apr 13, 2006 | 09:01 AM
RDON's Avatar
RDON
Dennis one more short question and I wont bother you anymore. (today)LOL
Can you till me the color.It is white but was there more then one white?
Thanks again Don
Old Apr 13, 2006 | 11:33 AM
Mil1ion's Avatar
Mil1ion
M is Wimbledon White.
The same white that is used in every Two-Tone colour scheme.
Old Apr 14, 2006 | 07:45 AM
BigShelby's Avatar
BigShelby
38 J is your axle code. J probably stands for power steering being the truck is 2wd. Find an axle code list and you will know your axle ratio.
Old Apr 14, 2006 | 10:05 AM
Mil1ion's Avatar
Mil1ion
So Don, Do you want all that other stuff decoded ?
I could have done it all if you wanted
carllouis
Mar 23, 2017 04:11 AM
Rangerdanger33
1983 - 2012 Ranger & B-Series
Jul 18, 2005 06:37 AM
oppy
16
Dec 30, 2003 03:18 PM
masterbeavis
May 6, 2002 10:38 PM
jowilker
May 20, 2000 01:10 PM
