Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
shop floor coating
Old Feb 2, 2004 | 01:22 PM
Turbo Indian's Avatar
Turbo Indian
it's [ tile clad hs] and it's about $48 per part and it takes to parts that covers about 600sq' I swear by it I do alot of welding and mechanical work in my shop the only thing I have found to hurt it actualy stain it was old thick grease from a jeep I worked on. the welding and air arc left a couple tiny spots but my floor is blue with a broom finish to prevent slipping, that also helps to hide some marks .I did about 1500sq' of my shop it cost me about $400+ but I think it was money well spent.
Old Feb 3, 2004 | 04:24 PM
bigredneck61088's Avatar
bigredneck61088
i never used any acid, the only prep i did was sweep the floor
Old Feb 4, 2004 | 05:17 AM
Bargod's Avatar
Bargod
How well do you think it would hold up to the steel wheels on an enginh hoist or stand? I have both and don't want to waste time painting my garage floor if it is going to flake off from my normal abuse.
Old Feb 4, 2004 | 08:15 AM
sorensenj's Avatar
sorensenj
I found using laquer thinner on oil and grease spots not only pulls the oily stuff out it drys up good when you are done. Makes clean up for coating easier IMO.
Old Feb 4, 2004 | 05:54 PM
Turbo Indian
I used old scafolding with steel wheels to finish the sheetrock on the ceiling, the only problem I had was where I ran over a sheetrock screw it left a tiny chip. I also talked a good friend into it by throughing a junk turbo on it again a tiny chip. this stuff is repairable
Old Feb 4, 2004 | 06:06 PM
Torque1st's Avatar
Torque1st
Posting Legend
You can repair chips in an epoxy floor coating with 5-minute epoxy. Just check to make sure that it is mixed right and that it hardens properly. I bought some consumer grade 5-minute epoxy once that wouldn't harden, -what a mess!! Now I check every tube I buy before I use it to make sure it is good. If you have access to industrial grade epoxy I would suggest it before the homeowner stuff.
Old Feb 5, 2004 | 09:35 AM
Bargod's Avatar
Bargod
Where can I find the good stuff and how much does it cost (generally)?
Old Feb 5, 2004 | 04:08 PM
Turbo Indian
I bought it from our local sherwin williams store it's $48 per part, each part is 1 gallon, so it's $96 and that will cover 600 sq'
Old Feb 7, 2004 | 09:06 PM
92GT5ohRed's Avatar
92GT5ohRed
I have tried a few paints and epoxy coatings over the years. We just built a new house with a 3 bay detached garage. I wanted the "real deal" this time because I have had disappointments with the others. I found the company who supplies and treats floors for car dealer service bays and Jiffy-Lube oil change stores. They are http://www.concrete-floor-coatings.com/concrete.htm The stuff is amazing. It has been down about a year. There is minimal wear where I park my superduty and no wear where my wife parks her 4-runner. We have a long stone driveway too, so the tires are always tracking in various stones and running over them. If we had paving, it would be flawless I am sure. I have left oil and grease on there, a week later it wipes off. It is slick when it is wet but I like the shine so I did not add the grip (sand) stuff. It is some work for prep, but it is real epoxy and real good. My garage floor is 25x35 and it cost around 400.00 to do it all. They provided EVERYTHING even tape for the molding and masking. Let me know if you want to know more.
p.s. my floor looks like the one on the web site, nice sheen and all.
Old Feb 13, 2004 | 01:10 PM
DragTruckin's Avatar
DragTruckin
garage floor paint
anyone have suggestions for what i should use to paint my garage floor? i've heard of companys that make certain products specifically designed for this purpose but i cannot remember their names.
Old Feb 13, 2004 | 01:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
Read this thread and the others on the subject.
Old Mar 5, 2004 | 03:05 PM
dzaborow's Avatar
dzaborow
garage floor paint
Any one looking for a garage floor coating I ran across this web site http://www.originalcolorchips.com
They have many options that allow you create your own custom floor. Check it out. They are very helpful if you would like to call or email them to find out more about their product.
Old Mar 22, 2004 | 06:02 AM
  #28
chaotik's Avatar
chaotik
Play it safe...use race deck flooring. Comes in a bunch of colors, so you can make a design.
And if you move, you can take it with you.
Old Mar 23, 2004 | 03:20 AM
  #29
RebelCounty's Avatar
RebelCounty
My buddy had his floor coated with an urethane coating, his father in llaw is a painter and recommended this stuff even over expoxy. I dropped a claw hammmer and didnt even phase it.
Old Mar 27, 2004 | 09:56 PM
  #30
Broncobirdy's Avatar
Broncobirdy
I used hot tracks brand on my last garage. I hated it. The tires left marks EVERYWHERE! No shine either...I have not decided for this house.
grandaddy's66
2004 - 2008 F150
16
Aug 6, 2010 02:46 PM
grandaddy's66
54
Jan 28, 2010 11:46 PM
grandaddy's66
39
Aug 6, 2009 12:09 PM
grandaddy's66
Dec 15, 2003 04:16 PM
grandaddy's66
30
Oct 5, 2003 09:32 AM
