Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
shop floor coating
Old Jan 25, 2004 | 10:53 PM
grandaddy's66's Avatar
grandaddy's66
shop floor coating
I am giving serious thought to coating my 20x26 garage floor. Any thoughts? I've seen it all advertised and am wondering what others have done. Thanks
Old Jan 25, 2004 | 10:59 PM
Torque1st's Avatar
Torque1st
Posting Legend
There are several threads here on floor coatings that can be found by the search function for quick information.
Old Jan 25, 2004 | 11:05 PM
grandaddy's66
Thank you, sir!
Old Jan 26, 2004 | 03:04 AM
haroutd's Avatar
haroutd
From: I'm lost somewhere in NJ -- can someone please find me?!?!?!?
Cheapest way is to go with one of those epoxy-based systems found in the paint aisle of your local Home Depot. They hold up well enough, and are a relatively inexpensive do-it-yourself solution. If you're looking for something more serious (and costly) do the search like Torque said.
Old Jan 26, 2004 | 06:19 PM
Gordon Dully's Avatar
Gordon Dully
I used the Rust oleum brand in my wifes garage and it didn't hold up but they did send me some more to redo it with haha chips and all But I put the industrial grade in my play garage and it is holding up very well after 5 yrs I used white it makes it easyer to see as you get older haha
Old Jan 26, 2004 | 07:52 PM
Nev. Bronco's Avatar
Nev. Bronco
Why alot of paints and sealers fail is because moisture is coming thru the cement from the ground and a vapor barier has to be laid on the ground before the cement. An epoxy type would be better but not a total fix.
Old Jan 27, 2004 | 04:00 PM
bigredneck61088's Avatar
bigredneck61088
get some drylok, most home improvement stores have it. it comes in alot of colors and is easy to roll on, i got it in my shop
Old Jan 27, 2004 | 04:03 PM
Torque1st's Avatar
Torque1st
Posting Legend
Does that drylok wear well?
Old Jan 27, 2004 | 06:48 PM
bigredneck61088
we have had it in the shop for around 3 yrs and shows no sign of wear except needing a good sweeping
Old Jan 27, 2004 | 08:38 PM
maa139's Avatar
maa139
I'm the second tennant in my garage, and the previous owner parked a dog (liked to mark it's spot) in there. I tried as best I could to get the spot up, but its in there and not coming up. But I figure, it's a garage, not a museum. I just got a gallon of cement sealer and rolled on two coats. Every spill wipes up nice and easy now. Doesn't look that great, becuase the spots are still there, but like I said...it's not a museum.
Old Jan 27, 2004 | 10:18 PM
Torque1st's Avatar
Torque1st
Posting Legend
That UGL Drylok is supposed to get right into the pores on the concrete and seal it up. I didn't know how durable it would be but it sounds better than epoxy.
Old Jan 29, 2004 | 10:58 PM
Gordon Dully
If you use epoxy after you mix it and the stand time you better be ready to put it on because you don't have much time to do it I didn't think my garage floor was that big till I had so little time to paint it and try and not get dry joints
Old Jan 31, 2004 | 10:57 AM
RexB's Avatar
RexB
RedNeck, does the cement need to be etched w/ muriatic acid before Drylock is used?
Old Feb 1, 2004 | 06:46 PM
Turbo Indian's Avatar
Turbo Indian
I did my shop floor 3 years ago I have left brake fluid on the floor over night and it was not even hurt if brake fluid does'nt hurt it nothing will. the mirical stuff is sherwin williams!!
Old Feb 2, 2004 | 02:33 AM
Torque1st's Avatar
Torque1st
Posting Legend
What kind of Shewrwin Williams?
