smog control
Old Jan 25, 2004 | 10:07 PM
holla-if-ya-hear-me's Avatar
holla-if-ya-hear-me
Question smog control
In 2002 I had to buy a new motor. When I recieved the bill I also recieved info that my smog control was removed, unproffessionally I might add. How can I get a new smog control and how can I put it on??
holla!!
Old Jan 25, 2004 | 11:22 PM
95 F150's Avatar
95 F150
Okay I'll bite , what smog control stuff was removed , smog pump, charcoal canister, EGR?? A salvage yard might be a good plae to start.
Old Jan 26, 2004 | 10:18 PM
holla-if-ya-hear-me
I'm not sure what all is missing, I think just the hoses. When I got a new motor put in the mechanic told me he just bypassed the smog control. It ticked me off a little bit because he didn't ask me before altering my motor. I wish there was something I could do about it.
holla!!
Old Jan 26, 2004 | 10:32 PM
frederic's Avatar
frederic
If your state, county DMV requires emissions controls, well, you need to put it back in there. This is often where Haynes and Chilton's manuals fall sort and Mitchel Manuals really shine. My local library has a full set from 88 through 2002, not sure if everyone's library is that kind. Expensive books.
But, get the emissions and vaccum routing diagrams and simply duplicate it under the hood, assuming your butcher, er, mechanic didn't disable any of the equipment with glue, a screwdriver, or other common means for destroying that stuff.
Any of the mechanical stuff thats been damaged, glued, removed etc you can either purchase new or from a junkyard. EGR valves I'd always buy new, after they have been sitting in a yard for a while they tend to rust shut, or open, which does you no good. THe purge canister and related solenoids, junkyard item all the way.
If its a ford part, and has the same number of hose ports and the same electrical connectors, don't think you have to get it from the exact same vehicle. Same year range is important because the wiring and hose ports will probably be the same, but all ford cars have emissions stuff
Sometimes you can get creative, I did an "air pump delete" on my F350 to use the brackets for a second alternator, and used Caddy Seville canister and a few other stuff and it breezed right through.
Good luck!
Old Jan 27, 2004 | 07:44 AM
holla-if-ya-hear-me
Cool smog control
I only have a Haynes manual, they don't carry the Mitchell but I may know where I can find one, Thanks.
holla!!
jeremy2008
Jun 2, 2009 03:19 PM
2 LoW
New York Chapter
Oct 23, 2004 08:03 AM
holla-if-ya-hear-me
27
Feb 1, 2004 10:38 PM
holla-if-ya-hear-me
Jan 25, 2004 10:22 PM
holla-if-ya-hear-me
Jan 13, 2004 07:48 PM
