what can i do??
Old Jan 12, 2004 | 09:09 PM
holla-if-ya-hear-me's Avatar
holla-if-ya-hear-me
Unhappy what can i do??
I'm about ready to my truck! I have a 93 Ford F-150 with the 5.0 and I am having a few problems with it:
1. My front tank fuel gauge only works when it wants to.
2. I have to manually change gears; it won't go into first gear; and when I come to a complete stop, it doesn't start in the right gear. (it's an automatic)
3. I also want to get better performance and don't know how.
Does anyone have any advice for me???
Holla-if-ya-hear-me
Old Jan 12, 2004 | 09:56 PM
christaylor's Avatar
christaylor
Shoot it lol
Only kidding
1 Pull the sending unit and replace
2 ??????????????????
3 How long have you had the truck?
Whenwas it last tuned up usual includung O2 sensor and such?
Chris
Old Jan 12, 2004 | 11:09 PM
parks911's Avatar
parks911
Re: what can i do??
Holla-if-ya-hear-me
1) front fuel gauge problem is most likely the sending unit.
2)Check tranny fluid, change tranny fluid & filter ~ including fluid in torque converter (hey, it may help)
3)What kind of performance do you want & how much are you willing to spend to get it?
Old Jan 12, 2004 | 11:13 PM
acerockola77's Avatar
acerockola77
For number 3 check out the 221, 260, 289, 302, 351w V8 forum, that's a often asked question.
Old Jan 13, 2004 | 07:20 PM
holla-if-ya-hear-me
I appreciate all the advice. do yall think that because my front seal is leaking that it may be the problem?
holla
Old Jan 13, 2004 | 07:34 PM
924x2150's Avatar
924x2150
My 1992 4.9 has the intermittant front tank guage problem too. I just popped off the connector from the top of the tank and found the 4 pins and plugs full of nasty grease and dirt. I guess someone put some kind of grease in there to inhibit corrosion. I hit both sides of the connector with CRC electronics connector cleaner and scrubbed with an acid brush. I rinsed them with some more CRC and dried them with compressed air. I sparingly coated the 4 pins with dielectric grease to help fight dirt and corrosion. My truck is on Jack stands for another day, but I will try and get back to you in the next week, if it helped or not.
My theory about the connector is based on one simple thing. Ford replaced a bad front sender for me. The original sender and new sender did the same thing, which was intermittant gauge reading.
Old Jan 13, 2004 | 07:48 PM
holla-if-ya-hear-me
I may try that. I had to replace my torque converter about a month ago and it started working for about a week, then it stopped. maybe i have a loose wire. I just don't know???
holla
fishindave11
1978 - 1996 Big Bronco
Mar 9, 2012 06:36 AM
scarole
New York Chapter
Nov 16, 2007 07:55 PM
holla-if-ya-hear-me
27
Feb 1, 2004 10:38 PM
holla-if-ya-hear-me
Jan 27, 2004 07:44 AM
holla-if-ya-hear-me
Jan 25, 2004 10:22 PM
