Sponsored by: Auxito
Cylinder Missing - Cause Damage???
Old Jan 21, 2004 | 09:29 AM
mcdev's Avatar
mcdev
#8 is missing pretty bad in my truck, gotta change out the COP, but its 16 degrees out today and I don't have access to a garage. I was wondering if I could cause any damage to the engine by driving the truck before fixing the miss. One last thing, #8 is on the passenger side, right? Thanks guys.
Old Jan 21, 2004 | 09:48 AM
Alton Ray's Avatar
Alton Ray
I don't know about the damage aspect but I believe the #8 is the back cylinder on the driver side. Good Luck.
AR
Old Jan 21, 2004 | 05:25 PM
LxMan1's Avatar
LxMan1
Well, it is never good to drive a newer vehicle with a dead cylinder. The reaw fuel that doesn't get burned will try to foul the plug, O2 sensor and is not good for the cat converter either. Not to mention the vibration.
But, if you have no choice, then drive it if you have too. That sure is aweful cold to be out in the open to work on a COP.
Do you know anyone who will let you borrow some garage space long enough to repair it?
Jimmy
Old Jan 21, 2004 | 08:29 PM
mcdev's Avatar
mcdev
Unfortunately none of my buddys out here have a garage available, and if they do, its not high enough to get the truck into.... Had to drive it a decent distance today for a job interview, didn't have a choice, so I am just gonna sack up tomorrow and tackle it. Thanks for the help guys.
Barry
Old Jan 22, 2004 | 11:45 AM
LxMan1's Avatar
LxMan1
Good luck.
Old Jan 22, 2004 | 03:29 PM
mcdev's Avatar
mcdev
Well, I change it out and it didn't seem to help any. When I pulled the plug it was kinda wet, but not too bad... After I changed the COP and disconnected the battery to clear the computer, I went for a test drive and it still had a rough idle, vibration at speed, ect... Check engine light came back on too.... This is killing me.
Old Jan 24, 2004 | 10:57 AM
knolsen's Avatar
knolsen
On the cyclinders I was getting a HARD code reading on #5 & 8 with 'key-on-engine-off', I found the problem was the connections between the COP and the spring. I removed the rubber boot from the COP and gently twisted and pulled the spring out of the COP. The connector inside the plastic housing was corroded/oxidized, probably caused by moisture and lack of a good tight fitting. I took some emory cloth and a small file and cleaned and sprayed them with a little electric contact cleaner. Next I slightly crushed the end of the spring to ensure a tighter fit.
I went through the rest of the COPs and found the same thing, even though they were not registering but were intermittent. Cleaned them up as well and now it runs great and I didn't need to purchase any new components
Might be worth pulling one of the easier COPs and inspecting it.
Good Luck
arkredneck
23
Jan 18, 2015 10:28 PM
Tile Guy
Oct 22, 2011 04:15 AM
highsmit99
Apr 3, 2011 04:53 PM
Customcab
Nov 16, 2007 03:33 PM
WonderDonkey
Sep 22, 2007 03:16 PM
