428 crank, 390 rods
alright thanks, that clears some things up, my dad has a 76 f250 and it had a older car motor put in it which they thought was a 390 but i got looking on the block and on the outside of the block it has reinforced ribs on it, and my book says only 410 mercs had the reinforced ribs on the outside of the block, maybe i should do more checking.
I've never heard of anything having ribs other than a 427, check to see if the mains are cross bolted, if they are its either a 427 or a 406. Some 406's were cross bolted, but all 427's have cross bolted mains. Ford produced 20 something different casting numbers for the 427, but if you can get me a number off the block and heads I can probably give you a good idea what it is (was). Good luck!
dslman1
05-05-2010 06:38 PM
tater_51
17
02-21-2010 05:48 PM
oldmaninva
18
02-18-2006 05:23 PM
bshackelford711
05-19-2005 09:47 AM
77fordguy
02-15-2005 08:36 AM
