460 stroker
Old Jan 14, 2004 | 11:47 PM
scottie2hottie's Avatar
scottie2hottie
Question 460 stroker
I have a 460 motor out of a 76 pickup. The stock stroke for a 460 is 3.9". I have purchased a 4.5" stroker kit containing crank and rods to create a 544 ci motor (with the block bored to .030). Would this motor need modified heads or is there enough deck clearance with stock heads to allow the change in stroke??
Old Jan 14, 2004 | 11:58 PM
airharley's Avatar
airharley
You'll need to mock up the crank and rod and check for clearance issues with the block skirt and cylinders at the bottom. If I am not mistaken you need .060 clearance between the rod bolts and the skirt. You can use any heads you want as the design of the stroker keeps the pistons inside the deck. Check with who you bought the stroker kits to make sure what I wrote is correct.
Old Jan 15, 2004 | 12:03 AM
There Goes The Neighborhood's Avatar
Factory stroke is actually 3.85". You should have no problem with stock heads, but I highly recommend a set of D0VE or equivelant, or even Iron CJ(D0OE-R) or PI heads(D2AE). A set of Al SCJ heads would be great, but I don't know the budget, so these are only suggestions.
Old Jan 16, 2004 | 12:09 AM
Brian460's Avatar
Brian460
You might read my thread regarding this same topis there is a lot of info there
https://www.ford-trucks.com/forums/s...hreadid=191829
Old Jan 18, 2004 | 05:00 PM
Brian460's Avatar
Brian460
There is some 429PI heads on e-bay right now
Old Jan 21, 2004 | 12:07 AM
scottie2hottie
thank you for your responses
AK FORD GUY
20
Aug 20, 2009 03:41 AM
robertbourque
May 12, 2007 06:08 AM
MychalCrowson
24
May 10, 2007 03:07 AM
Mtthwvn73
13
Feb 7, 2006 08:09 AM
brownd019
Aug 23, 2003 11:57 PM
