stroker kit
Old Feb 2, 2006 | 05:28 PM
Mtthwvn73's Avatar
Mtthwvn73
Question stroker kit
I was wondering if anyone makes a stroker kit for these motors, i'd love to make this big six into a stroker. what are the lenth of the stock rods? if they don't make a stroker kit for it has anyone used a set of longer rods to stroke it out? i would love to see some company make a stroker kit for these motors...i just don't know of any. i would also like to know the dimentions of this motor...i've heard they have one of the longest strokes, except for the new 5.4's
Old Feb 2, 2006 | 07:35 PM
fastback69's Avatar
fastback69
You'll have to get the crank offset ground by a machine shop. I don't know what the max offset is. The rods are 6.2097" CL-CL. Stroke is determined only by the diameter of the circle that the rod throw travels.
Old Feb 2, 2006 | 08:14 PM
309Ford's Avatar
309Ford
The 300 is 4.00" bore 3.98" stroke. Stroking the motor is not considered a good idea in many circles. The extra stroke length increases sideloading of the pistons, with a decrease in engine longevity being the probable result. The motor is probably close to its maximum practical stroke. The rod ratio is already a bit unfavorable; increasing the stroke makes it much worse.
Clifford makes, or made, a stroker kit, but for the money it cost you'd be better off spending the cash on other upgrades like a turbo if you had the ability to get one fabricated. They are flat out pricey.
Old Feb 2, 2006 | 08:43 PM
300pinto's Avatar
300pinto
The Clifford kit IIRC came out to about 348 cu. in.I've read where at least one Comp Eliminator racer was running a 320" motor.The 240 rod is 6.7" long
Old Feb 3, 2006 | 06:29 AM
Mtthwvn73's Avatar
Mtthwvn73
the reason i was asking about a stroker kit for it is to where i could get more torque outta this motor, i am not worried about horsepower...i just want pulling power, and i thought that a stroker would be the best way to get the kind of torque i want. it is a great pulling motor right now...but it could still use a that little bit more .
Old Feb 3, 2006 | 11:08 AM
MThad's Avatar
MThad
How much torque do you want?
With the right head work, 1.92/1.60 valves, 10.0:1 Cr, the right cam, carb and intake 300 ft/lbs is possible. Include full hot rod build-up, roller rockers, hyd roller lifters/cam, balance/ blue print, windage tray, bolted together with ARP------
Old Feb 3, 2006 | 01:58 PM
Silver Streak's Avatar
Silver Streak
Stroking the engine is a horribly inefficient way to increase output. You are better off spending the money on the top half of the engine. There are only two cases in which a stroker is a reasonable alternative, and they are related: 1. If you are building such a strong engine that you will need to buy aftermarket rotating/reciprocating components anyway. 2. If the power output desired cannot be achieved without moving the operating rpm out of the desired range.
The search button at the top right of the page can achieve awesome things when used. This topic has been discussed at length on more than one occassion.
Old Feb 3, 2006 | 02:42 PM
Mtthwvn73's Avatar
Mtthwvn73
well...i did search for stroke...stroker...punch, and didn't get anyhing, so i thought i would ask. thanks for the information....so it would be best to build the top of the the instead of trying to stroke it? i don't really want to do any kind of porting, because i have heard that this will drop your low end torque...so i will probably get a set of higher c/r pistons...bigger injectors...and maybe get the intake ported.
thanks for all the advice,
matt
Old Feb 4, 2006 | 01:21 AM
Col Flashman's Avatar
Col Flashman
Look here, the 300c.i.er is already a Stroked 240c.i.er.
If you desire more FPT, the Best way toi acheive it is to make the 300c.i.er BREATH.
Minimal P&P (otherwise you defeat the purpass by taking to much off), Oversized Valves, Offenhauser C Intake w/ a 390 to 600 CFM Holley Carb, a 2-into-2 Header, 3" Dia Exhauste Pipes into Magnaflow Mufflers.
Old Feb 4, 2006 | 08:24 AM
Mtthwvn73's Avatar
Mtthwvn73
what if you have EFI...what are some ways to make it breath better? i don't know of any companies that make an aftermarket intake manifold for the 300-6, if i could find one i'd definately buy it...and i know this is a stupid question but what does P&P mean?
Old Feb 4, 2006 | 10:15 PM
Col Flashman
EFI isn't in my purview.
I've already Listed in my Previous post to you how to make the 300c.i.er Breath better, but here it is again.
"Minimal P&P (otherwise you defeat the purpass by taking to much off), Oversized Valves, Offenhauser C Intake w/ a 390 to 600 CFM Holley Carb, a 2-into-2 Header, 3" Dia Exhauste Pipes into Magnaflow Mufflers."
I've Also listed for you in my Previous message to you that "The Offenhauser 'C' Intake" is what you'll need, see above, you'll find one on e-Bay.
Porting & Polishing.
Anthing else?!.
Old Feb 5, 2006 | 09:03 AM
Mtthwvn73's Avatar
Mtthwvn73
lol...sorry...nothing else, i started thinking about the P&P, and it clicked to me. i looked at your gallery...man you have done alot to that thing! I was thinking about getting another straight 6 instead of changing EFI to carbed (i was going to build up my 95). thanks alot for the information...twice lol
Old Feb 5, 2006 | 10:32 PM
Col Flashman
No worries, that why we, including you, are all here, to help out those we are able to.
Old Feb 7, 2006 | 08:09 AM
77300i6's Avatar
77300i6
Increase the VE, that increases BMEP, which is directly proportional to torque output.
A BMEP of 150.8 psi = 1ft-lb./cu. in.
332_58 f100
Jan 2, 2008 07:37 PM
scottie2hottie
Jan 21, 2004 12:07 AM
mdh627
17
Aug 27, 2003 08:50 AM
fordlowboy
16
Feb 7, 2003 06:22 PM
rickc
Feb 6, 2001 04:07 PM
