4 wheel drive hub Question
Old Jan 14, 2004 | 06:53 PM
Chips2000's Avatar
Chips2000
I have a 99' Powerstroke 4x4 with manual locking hubs and I have been told these are better than remote locking hubs, although less convenient. My brother is looking to buying a 99-2003 Power Stroke and was surprised my truck did not have remote locking hubs. He has a Tahoe with the remote hubs and really likes them and has had no problems. What are the pros and cons? He is now not sure which to look for while he shopping for a PowerStroke.
Thanks!
Chips2000
Old Jan 14, 2004 | 07:11 PM
Chips2000's Avatar
Chips2000
I just found a similar recent post that may have answered the questions my brother has.
Thanks,
Chips2000
Old Jan 14, 2004 | 09:29 PM
zanec209's Avatar
zanec209
I have a 97 powerstroke with manual hubs and i really like them. First off ive had a lot fewer problems with them than the automatic ones. The main reason i like them is if you really need a bunch of pulling power to back a trailer up a steep hill lets say from a stop, you can not lock in your hubs, and put your vehical in 4-lo, this gives you a ton of power to your rear wheels.
Old Jan 15, 2004 | 01:00 PM
AKDieselMan's Avatar
AKDieselMan
I have a 99 super duty with auto hubs, I won't make that mistake again. Vacuum leaks can cause a serious wreck. I was lucky, coming slowly down a steep snow covered grade, as I applied the brakes the rear end got loose and finally resulted in a complete three sixty. The truck was stuck. I manually locked the hubs and drove out of the ditch. After investigating I found the light stays on even when the hubs are not locked any more from a loss of vacuum. I manually locked the hubs after that and have not had the same problem, same steep hill every morning going to work. What happens is this. When you break at slow idle speeds with the hubs unlocked the front wheels want to stop, the rear don't because the engine is applying torque, result is uneven breaking between front and rear wheels. I have had the truck to the dealer for warranty service and finally gave up. Service manager even hinted he wouldn't own auto of this type. If this truck wears out before I do I won't replace it with another with auto hubs. I've had it since new.
tjc transport
16
Feb 7, 2015 06:32 AM
Boatbum01
Jul 15, 2010 03:55 PM
cmorningstar01
1983 - 2012 Ranger & B-Series
Mar 20, 2010 07:18 PM
63DH8
2004 - 2008 F150
Jan 21, 2010 02:30 AM
stormyrider
Offroad & 4x4
Dec 16, 2007 06:31 PM
