Offroad & 4x4
manual hubs
Old Dec 15, 2007 | 04:14 PM
stormyrider's Avatar
stormyrider
manual hubs
My 2000 F250 superduty will not lock into 4 wheel drive. Transfer case shows it is in 4H and the manual hubs click in but no 4 dheel drive. I have heard the factory lockout hubs don't last but I only have 82000 on this. Is there a fix on these or am I looking at new hubs? Which after market hubs are the best?
Old Dec 15, 2007 | 05:41 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
well, are you axles spinning?, that would be a good indications if that your hubs are broke.....but if your front dshaft isn't spinning then your tcase is bad, or if the front dshaft is sprinning and axles are not, look into your diff.....easy!
Old Dec 15, 2007 | 05:42 PM
quadzjr's Avatar
quadzjr
its a matter of personal preference....ive tried them all, MY personal favorite is the MM premiums......others like the warn premiums etc etc....
Old Dec 15, 2007 | 06:50 PM
RogueSpear2023's Avatar
RogueSpear2023
do you have manual t-case or ESOF?
Old Dec 16, 2007 | 12:23 PM
stormyrider
Mine is the manual engage with the lever on the floor.
Old Dec 16, 2007 | 06:31 PM
yankeerider's Avatar
yankeerider
All it takes is one hub not engaging to keep the front axle from driving. Lock both hubs, shift the transfer case into 4hi, and with the truck not running, jack up one wheel at a time and try rotating it by hand. If you can rotate it, that hub is not engaging.
Jager
Sep 26, 2009 05:05 PM
arhuranna
May 21, 2009 02:44 PM
syannuzzi
Sep 7, 2007 01:20 PM
MisterCMK
Oct 25, 2006 03:47 PM
plb150
Offroad & 4x4
Apr 9, 2004 09:48 AM
