Exhaust setup for max HP...
Old Jan 17, 2004 | 11:10 PM
modru2004's Avatar
modru2004
i don't pay much attention to sigs, reguardless i missed it when i posted, sigs don't show up when your posting. anyway indeed you say 5.8 in your post and 5.0 in sig. which is it, as there will be a difference in sound.
Old Jan 18, 2004 | 11:13 PM
peppy's Avatar
peppy
I'm either confused or cant type. Could be either. Sorry, its a 5.0 under there somewhere.
Old Jan 18, 2004 | 11:58 PM
modru2004's Avatar
modru2004
go to the site i posted and listen to the 351 2.5 no muffler and go listen to some of the 302 clips. sound won't really be to much different between the 302 and 351. i personally like the flow 40 no cat turndown clip. i thought it sounded awesome.
Old Jan 25, 2004 | 05:13 PM
94F150-408's Avatar
94F150-408
well,
The old dual vs. 3" debate eh?
Heres a tidbit for you doubters out there (modru). Anderson Ford Motorsports has run some of the fastest Mustangs out there. When I was setting up my 408 in my Bronco in 99, they (Anderson Ford) were running a faster 1/4 mile with a straight 3" / bassani type crosover than the dual 2 1/2's due to the additional scavenging effect that the 3" had...so, the moral of the story is that a well built single 3" can and will perform at least as good and probably better than most dual setups.
BlaCksiLo is correct on both the additional scavenging benfits and proven dyno results on the single 3". This is not to say that you wont benifit from a dual set-up, but the dyno and racetrack dont lie.
Old Jan 25, 2004 | 06:40 PM
modru2004's Avatar
modru2004
like i said a properly built dual setup will perform best.
Old Jan 25, 2004 | 10:25 PM
Blly177's Avatar
Blly177
a single 3inch will give the best performance because it gives the exhaust more velocity sometines more velocity will flow more than a bigger pipe
Old Jan 25, 2004 | 10:57 PM
modru2004's Avatar
modru2004
er im getting confused as to what part of this discussion we are discussing. the dual vs single? i know a single 3 inch is has very good performance for single exhaust. but a PROPERLY built dual exhaust will provide much better gains than just the single.
Old Jan 26, 2004 | 12:12 AM
94F150-408's Avatar
94F150-408
Not true modru...see my post above regarding a better 1/4 mile with a single 3", also there are dyno tests out there the say a single works better. velocity, velocity, velocity.
Again, the dyno and the racetrack dont lie!
Old Jan 26, 2004 | 12:35 AM
BLaCkSiLo's Avatar
BLaCkSiLo
thanks 94F-150-408, i think my 3" install has been a great success, the mileage increase isnt anything to call home about but the performance is, i think it would have the same with a true dual setup but a lot less money becasue you only have to buy 1 muffler and a lot less tubing, either way, i'm happy with it
Old Jan 26, 2004 | 07:29 AM
modru2004's Avatar
modru2004
ive seen your post......
the_auto_tech
2009 - 2014 F150
Jul 22, 2017 12:48 AM
dschr60
Sep 20, 2016 10:23 AM
bigcrunch
13
Jul 22, 2016 10:16 PM
Meats12
17
Jun 11, 2015 12:56 PM
fordboy300
13
Jul 16, 2013 07:12 PM
