Sponsored by: Real Truck
Question about rotors...
Old Aug 3, 2002 | 12:48 PM
DJR 17's Avatar
DJR 17
My rotors are warped again(nothing new)and have been turned before. The truck has 70k on it now. My question is should I replace them or turn them again. They are thick enough to turn again, but I was thinking they might not balance correctly, since they would be cut more on the high sides. Also Im going with a ceramic pad, anyone try these yet?
1999.5 F-250 V-10 4x4 CC SWB Lariat 3.73
Old Aug 10, 2002 | 09:43 PM
Monsta's Avatar
Monsta
Sit. Stay.
I'd replace them with some nice aftermarket ones myself. I would like ot hear about these ceramic pads too. However, the rotors I am going with come with pads already. (ART)
HEY! Why don't you get 'em, try them out and write up a little report?!
Old Aug 10, 2002 | 10:19 PM
HiTech's Avatar
HiTech
Are you putting your wheels on with a torque wrench to make sure the lugs are all at equal torque?
-Jim
2001 E-450 V-10 Superduty
Old Aug 11, 2002 | 07:45 AM
DJR 17's Avatar
DJR 17
Yep, they are torqued to 140 ft. #. What should the caliper assembley be torqued to?
Old Aug 11, 2002 | 08:07 AM
daimon1054's Avatar
daimon1054
ford rotors suck go with aftermarket. I have heard of Porche using a ceramic rotor but never pads. So let us know what you find. Rember though if you are having rotor problems a different pad may only cause more heat which will create an even bigger problem.
Old Aug 12, 2002 | 10:09 AM
Monsta's Avatar
Monsta
Sit. Stay.
ON 250s, 350s & Excursions ONLY!!!! The Motorhome is different!!
Front:
Pin bolts (the small bolt) 42 lb. ft.
Anchor Plate bolt (the big bolt that removes the whole caliper) 166 lb. ft.
Rear:
Pin bolt 27 lb. ft.
Anchor Plate Bolt 128 lb. ft.
Old Aug 14, 2002 | 07:53 AM
DJR 17's Avatar
DJR 17
Thanks for the info!
Old Aug 16, 2002 | 03:59 PM
DJR 17's Avatar
DJR 17
Well I got the new pads and had the front rotors turned, and the damn thing is still vibrating when I brake. I guess i'll do the rears next.. BTW the pads are Raybestos Quiet Stop ceramic pads.. very quiet and work real good so far..
Old Aug 20, 2002 | 06:20 PM
DJR 17's Avatar
DJR 17
Well it was the rears all along, I had them turned and replaced the rear pads and now its smooth again. I thought the rear pads would out last the fronts, but they both had even wear(front to rear)
Old Aug 20, 2002 | 06:28 PM
Distinctive Dave's Avatar
Distinctive Dave
ranstl
2004 - 2008 F150
Oct 30, 2010 09:02 AM
89CrewCab
Jan 2, 2010 11:44 AM
electrified_cc
May 31, 2007 01:49 PM
Enomra
1997 - 2003 F150
Oct 9, 2006 11:38 AM
fordiesel69
Mar 25, 2001 06:23 PM
